Re: hard suspension when brakes on Xantia v6 mk1
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 98
Re: hard surspension when breaks on Xantia v6 mk1
Ur, I thought that with the car stationary it stays in SOFT mode regardless of the brake pressure. Only the accelerator quick movement can make it switch to stiff suspension at speeds less than 30km/h (?)
Graeme M
- CitroJim
- x 6204
- Contact:
Yes, that is true Graeme...aerodynamica wrote:Ur, I thought that with the car stationary it stays in SOFT mode regardless of the brake pressure. Only the accelerator quick movement can make it switch to stiff suspension at speeds less than 30km/h (?)
It's one of the factors that makes things hard to test. Not even a Lexia/ELIT can manually switch modes which i find was quite an oversight on the part of the Hydractive designers...
Yep - find a competent Garage!!!rolyh wrote:Car now rides great, no jumping, breaking fine. But when I got to the MOT station they still failed it, and pointed out to be that all was fine, but when the break pedal was depressed the car suspension went solid, which was the case.
But if anyone has any other ideas I would be very great full.
What do they mean by "the suspension went solid" and how were they determining this exactly ? If they had one idiot sitting with their foot hard on the brake pedal and the other sitting in the boot bouncing up and down trying to move the rear suspension then of course it will be "solid", because the car has rear trailing arms the rear suspension cannot move when the car is stationary and the foot brake is applied. Try it!
Did they have the engine running during the test ? And by the way, since when do MOT testers "test" suspension moves up and down while the foot brake is applied ? What kind of test is this ?? 25 years taking cars for MOT's and I've never heard of this ??
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
You're right - pressing the brake pedal will not switch to hard mode when the car is stationary - even on a Series 1, which has a front brake pressure switch feeding into the Hydractive ECU. A slight tap of the throttle will put it into hard mode for 3.5 seconds though...aerodynamica wrote:Ur, I thought that with the car stationary it stays in SOFT mode regardless of the brake pressure. Only the accelerator quick movement can make it switch to stiff suspension at speeds less than 30km/h (?)
However, if the engine was stopped and they were sitting there pumping the brake pedal like idiots that would quickly use up the stored pressure in the accumulator and inadvertently cause the front suspension (and eventually the rear) to go into hard mode due to lack of main system pressure.
However if they were testing the suspension stiffness with the engine not running, they're idiots for that too...
Simon
1978 CX 2400
1978 CX 2400
- xantos
- My Cars: Xantia 1.9TD Break non-hydractive (1999)
Xantia 3.0 V6 Activa (1998)
C4 2.0 HDi Exclusive Mk2 (2010) - x 10
Mandrake wrote:If they had one idiot sitting with their foot hard on the brake pedal and the other sitting in the boot bouncing up and down trying to move the rear suspension then of course it will be "solid", because the car has rear trailing arms the rear suspension cannot move when the car is stationary and the foot brake is applied. Try it!
Mandrake wrote: However, if the engine was stopped and they were sitting there pumping the brake pedal like idiots that would quickly use up the stored pressure in the accumulator and inadvertently cause the front suspension (and eventually the rear) to go into hard mode due to lack of main system pressure.
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet )
C4 Exclusive 2.0 HDi (gear shifting b****!)
- CitroJim
- x 6204
- Contact:
Yes, those MoT testers definitely do not appear to be the sharpest knives in the block....
Thanks all,
Has anybod tried; with help of a second person, pressing the foot break and checking the suspension for movement at he same time, to see if it goes into sport(firm) mode in this condition; this is with the car stationary?
I have actually contacted Citroen direct; and they don't have an answer.
I think I explained this pretty well in my post - no, pressing the brake pedal while stationary does not put the suspension into hard mode.rolyh wrote:Thanks all,
It will however "lock" the rear suspension arm's thus making the rear suspension appear to go rigid. This is completely normal and certainly not cause for an MOT failure!
Simon
1978 CX 2400
1978 CX 2400
- CitroJim
- x 6204
- Contact:
Precisely!Mandrake wrote: It will however "lock" the rear suspension arm's thus making the rear suspension appear to go rigid. This is completely normal and certainly not cause for an MOT failure!
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
A thought, if they've got it going fast enough on the brake tester it could kick hard mode on!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
I haven't heard of testing the suspension and brakes at the same time either - except on the bikes, when they need to apply the brake TO test the suspension.. (if they haven't rollers)
Thank all,
It appears that this is the correct function of the car, as with the brakes on the trailing up in the suspension is ridged.
As well explained by Mandrake. Thank you Rolyh
- chinkostu
Re: Re: hard suspension when brakes on Xantia v6 mk1
Probably worth finding a better tester and complaining to VOSA
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Zelandeth
- My Cars: 2006 Peugeot Partner Escapade 1.6HDi.
1988 Renault 25 Monaco 2.0i.
1985 Sinclair C5.
1984 Trabant 601S.
1975 Rover 3500.
1973 AC Model-70. - x 1406
- Contact:
It's always annoying when you run into testers that are stumped by anything a bit odd.
Took me no end of arguing to get my Lada Niva through the test because of "excessive free play in the steering system." Yes, there's about a 1" dead zone at straight ahead. On a car with worm and pinion steering that is totally normal, and the numbers are right there in the test manual (up to 2" steering wheel movement is acceptable) for that. Must have taken me about an hour to get that sorted. Went back to my usual garage the year after!
Odd one I remember from one year though was nearly getting a fail apparently because of a defective steering lock. First off, how is that even a safety item that should even be tested? Secondly, Saab 900s don't *have* a steering lock! That was one of the big chains which I generally wouldn't let my car near as well had it not been necessary due to time. Got it sorted in the end but it made me scratch my head...
There's an awful lot to be said for having a garage you trust.
For MOTs your Local Council testing centre is usually a good bet, they're involved with testing taxis and all the Council's own vehicles (which VOSA *do* delight in spot checking) but don't do any repair work, so their incentive is to be thorough enough but they won't be looking for a reason to fail you. Never gone this route myself, but know several people who have and have all been happy.
Current fleet:
06 Peugeot Partner Escapade 1.6HDi, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 75 Rover 3500, 73 AC Model 70.
- Not Mike
- My Cars: '07 Peugeot 207 1.4 "Sport" (Ha!)
'04 Berlingo Multispace 2.0 HDi with a 123BHP remap - x 45
I use a place that only does MOT tests and no repairs near here. They're great, and will even take me under the car and show me what and why it's failed, or tell me exactly what is an advisory and why.
Sent from my SM-N9005 using Tapatalk
