I have had a bit of that on both C5s - quite alarmingly so on the first one.
In both cases injectors.
Cleaned and refurbished they run fine now.
Problem ahead
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1378
Re: Problem ahead
On the old idi engines that's a sign of heater plugs needing replacement. Not so for modern di engines (and you've had them replaced anyway) so I would suspect injectors letting the fuel in at too low a pressure. Have you done any live reading of the injection system at all?
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Re: Problem ahead
When/if I buy the works hdi, I'll swap injectors next winter and prove/disprove the old injector theory. I have 8 injectors and have changed them round to try to equalise them on the lexia. When she's warm she starts fine and the water heater makes sure she's warm when at home in the winter.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
- x 18
Re: Problem ahead
What's an 'idi' engine?
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4917
Re: Problem ahead
Indirect Injection - squirts into a precombustion chamber.xantiamanic wrote:What's an 'idi' engine?
- x 18
Re: Problem ahead
Thanks steve ... so an old type like an xud, yes, as opposed to an hdi?
Mike
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
Re: Problem ahead
Yep!
OnlinePaul-R
- Donor 2023
Re: Problem ahead
Apologies for the TLA.
Re: Problem ahead
Just to bump this back up again. Haven't done anything yet as problem has been gone. This morning on turning ign on, I got the beep and the warning lights. Back to old symptoms of starting with a splutter and smoking . Watched my temp gauge this time and sure enough........the needle swung up to hot and then instantly back down again. IME that is faulty temp coolant sensor. New one is here so will fit ASAP when carport and shelter are available.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
