I get this and I have always put it down to the fact that the wheel sensors are not aligned, so always ignored it.GiveMeABreak wrote:U1213 - Under Inflation Detection - Fault in the vehicle speed information received by the CAN from the ABS or ESP ECU. - Permanent - (but only on Diagbox Global Test - nothing on vehicle during running). All pressures measured and OK, so assume as car is stationary this would be normal.[?
Updated
I also get the F5FF code on the BSI, which has appeared on this site before (F5FF (unexpected re-initialisation fault coming from the BSI) Not Characterised.)
http://www.frenchcarforum.co.uk/forum/v ... hp?t=49948
