Why would you drive with sidelights and DRLs on, or does the car give you no choice (a la Volvo)?Stickyfinger wrote: On with ignition, off with headlamps via a relay............sidelights are only parking lights anyway
white exec wrote:Why would you drive with sidelights and DRLs on, or does the car give you no choice (a la Volvo)?Stickyfinger wrote: On with ignition, off with headlamps via a relay............sidelights are only parking lights anyway
Yep, fitted INSIDE the headlamp unit. With the Xantia the removal of the Glass Lens is easy as there are 8 spring clips and a rubber seal.GiveMeABreak wrote:Hard to see, but did you place the LEDs inside the headlight unit then? I've just had to buy a new Fog / Indicator light unit as must of broken the light seal somewhere or a stupid flimsy plastic tab when replacing bulbs. Tried sealing it up with silicon sealant after drying out, but one spec of rain and full of bloody water again - so sod it, bought a new assembly.
It works well. I've seen these in the metal as it were and Alasdair has dine a brilliant job of them...elma wrote: I like the sound of your mounting method. .
