So, bought myself an X7...
'13 3008 1.6 HDi GripControl - x 1003
Re: So, bought myself an X7...
The filler neck comes complete with the tank so the mis fuel device must be integral when built. It might be possible to remove it if you drop the tank and separate the filler neck from the cap mech outside. Otherwise you just need an insert the right diameter to spring the device - but your local garage might be a bit annoyed if you go along and hacksaw the end off a diesel pump on their forecourt....!! Given the current price of fuel and level of taxation I can't see that you're saving enough to make it worth the hassle unless you are doing 100k a year, but each to their own....
OnlinePaul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1382
Thanks for the info. It's what I feared but...RichardW wrote:The filler neck comes complete with the tank so the mis fuel device must be integral when built.
That's exactly the idea I had today at work. A short length of tube to push through the device. I just need to find out the diameter that's necessary.RichardW wrote:Otherwise you just need an insert the right diameter to spring the device...
Not obvious from Google, but it might be 24mm vs 21mm for the smaller petrol nozzle.
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
Plastic fuel can with spout works on mine.
Rick.
2013 Citroen DS 5 D/Sport
