C5 Mk1 Loose Accelerator Pedal Adjustment
Guides on how to approach the more common problems experienced by our members.
Please don't post in this forum but link to the threads here where necessary.
Anyone wishing to create a howto please submit to a mod or admin for inclusion here. Subject to being edited.
x 1874
Post by GiveMeABreak »
If your accelerator pedal is suffering from the 'droops', here's where you need to adjust it:
The accelerator cable has a fair bit of travel from the pedal to the throttle potentiometer and over time, you may find the pedal drops an inch or so. This of course will lead to reduced performance as there is too much slack.
The throttle sensor is housed in the nearside engine bay (next to bulkhead on battery side) under the fuse unit.
Remove the plastic covers, take out the fuse holder and you will see 2 x 10mm head bolts. Undo these to move aside the plastic compartment covering the throttle cable / potentiometer. There should be a circlip that fits over a corrugated plastic 'stop piece'. Adjust this as needed to give your throttle pedal a boost!
It has been noted that if you are built like a twiglet you may be able to access the unit without taking the fuse box out - it can be accessed from the side once the air intake housing is moved out the way - but is a bit tight!
faddy
x 4
Re: C5 Mk1 Loose Accelerator Pedal Adjustment
Post by faddy »
Presumably disconnecting the battery before messing with the fuse holder?
faddy
x 4
Re: C5 Immobiliser Fault
Post by faddy »
My question related to moving the fuse box to adjust the accelerator cable so should be with the other bit of the split thread....
x 375
Post by xantia_v6 »
Split posts moved here (which I think is where they belong).
