Pug 207
- x 6856
Re: Pug 207
I wouldn't go as far as probable but it certainly is possible. It could also be poor connections on cam position sensor or even dicky sensor. As for the ambient temperature issue could be dirty sensor, poor wiring connection or iffy ECU connecting plug. I don't know much about the Peugeot set up but is the sensor on the passenger wing mirror or behind the grill?
- x 64
Re: Pug 207
All good questions I don't know the answer to haha..mickthemaverick wrote: 29 Sep 2020, 21:23 I wouldn't go as far as probable but it certainly is possible. It could also be poor connections on cam position sensor or even dicky sensor. As for the ambient temperature issue could be dirty sensor, poor wiring connection or iffy ECU connecting plug. I don't know much about the Peugeot set up but is the sensor on the passenger wing mirror or behind the grill?![]()
It would seem to be a bit of a coincidence for several sensors to fail at the same time though
- x 6856
Re: Pug 207
Indeed it would, however the connections to those sensors may all be going through the same multiplug which could be where the problem lies. Worth checking the main fusebox and ecu multiplugs for corrosion and dampness in the abscence of more knowledgeable guidance from the PUG contingent!
- x 949
Re: Pug 207
Is the oil level correct? Is it running ok? Any unusual engine noises particularly on start up?
The BMW engine is not unknown for timing chain issues & fault codes relating to cam sensor/position/dephasing can be a warning sign that the chain or tensioner is getting slack or worn.
Make sure the oil level is good first as low oil level can also cause issues with timing chain tensioners & dephasers.
- x 949
Re: Pug 207
Just been reading through the original posts & noticed this.
Yes its a messy job but don't know if you are aware but may cars that use this setup with upward facing filters actually have a tiny drain plug on the filter housing to pre drain it before removing the filter, makes it way less messy. TU engines had them at the bottom of the filter cup, a little 3 or 4mm allen screw with a copper seal from memory.
- x 7387
Re: Pug 207
Cor! never knew thatwheeler wrote: 30 Sep 2020, 10:19 TU engines had them at the bottom of the filter cup, a little 3 or 4mm allen screw with a copper seal from memory.
Thanks Wheeler
- x 64
Re: Pug 207
That is interesting as she habitually runs it until the "check oil level" message comes up on the dash, not such a problem when she lived close as I would top it up for her, however now she lives in Norwich that doesn't happen. She recently came down to see us (socially distanced in the garden) and the message was showing, I expect she hadn't checked it since she moved up a year ago and pretty sure she drove down knowing it was low although she wouldn't admit this!wheeler wrote: 30 Sep 2020, 09:53 Is the oil level correct? Is it running ok? Any unusual engine noises particularly on start up?
Last time I went in it was running fine with no noises, it also goes much quicker than it has any right to. I'll ask her if that has changed.
- x 64
Re: Pug 207
I've done it a few times now and it isn't that messy at all and I think I read somewhere (BOL maybe?) that it has some sort of valve that stops it running out as the filter is removed, if that's the case it works well.wheeler wrote: 30 Sep 2020, 10:19Just been reading through the original posts & noticed this.
