C5 x7 steering rack leak
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Re: C5 x7 steering rack leak
I wish we lived in the USA and could take a "class action" over such design failings
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Yep - I hear the US already has a minimum life / tread for car tyres expectation for consumers - they should bring that in over here for sure.
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
It might be a good idea for those with racks that are not yet leaking to spray some grease around the shaft.
- Locked user account
- My Cars: A used Citroen
- x 27
@ jgra - I think the leak occurred between the pinion housing and the rack housing ... the guy knows his stuff (although quite young), and said that he uses kits with full rubbers and seals, and that the entire unit will be sand-blasted, and after he's done, the pinion shaft will be enveloped in a protective grease-like substance, that should be hard to take off with average road conditions ... the job should be completed by wednesday noon ... I'll post photos of the reincarnated steering rack, just to give people some before-after opportunities for evaluation ... if I could get 3 years of life out of it, that would be a great deal IMO
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
good stuff VB, for some reason I thought the problem was a seal at the outside of the Pinion Housing..
- x 27
Actually it couldn't, the constructors, for whatever reason, disabled this possibility by putting this on the back side of the pinion part:Stickyfinger wrote:I am thinking a gaiter or the correct size could me obtained and fitted to avoid the corrosion ?
That point gets attached to the chassis, or wherever ...
- Stickyfinger
AX, little Daffodil
- Contact:
What about paint on "Rubber paint" or an PV sealant ?
- x 27
Here's how it looks like repaired (already collected today), there is high likelihood that tomorrow the car will be on the road by the end of the day.Stickyfinger wrote:What about paint on "Rubber paint" or an PV sealant ?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
What about all that rust?..... oh it's copper grease
Looks like a good repair
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 27
Will let you know in two years' time ... hopefully, three ...Lighty wrote:Looks like a good repair
- Stickyfinger
AX, little Daffodil
- Contact:
Is the shaft full exposed all the time then ?
- old'uns
- My Cars: '02 C5 - gone
'09 X7 - gone
CMax - X7 replacement - gone
Acadiane - lost to a V5c applicant
'06 C5 VTR auto est
'90 Honda Beat
'73 ST70 Dax
'75 ST Dax - 120 powered - x 127
apparently so according to my garage.....mechanic reckons for some reason Citroen placed the rack further away than usual which means that where the shaft/UJ etc is tucked partly into bulkhead/floorpan for protection, on an X7 this is now exposed.
i'll assume there is a 'good' reason why Citroen designed it this way but.....................maybe the designers were good friends with VW software engineers ie people with a grudge against the Co.
- Stickyfinger
AX, little Daffodil
- Contact:
I still cannot see why it cannot be sleeved in some manor to protect it at the seal. There is no pressure after all......just cannot get a pic in my head of it ....
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
I'm sure both my Mk1 & 2 C5 racks were covered in a thick plastic sheeting. Never had any issue with either of those.
