C5 x7 steering rack leak
Re: C5 x7 steering rack leak
Not sure why that would;d be ?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- Locked user account
- My Cars: A used Citroen
- x 27
I think I'll try first the repair method on my steering rack ... the reparation process is 130 GBP, and what needs to be added to that amount is the taking off and mounting back the steering rack (which I'd let the Citroen Service to do) ... the company that does this should be the best one in Croatia (specialized in steering racks and servo pumps) ... if the refurbished one would function for the next 4-5 years, that would be a real bargain (compared to the new rack, no matter how cheap I may find it)
- x 27
Anyone has any extra advice, should I do something else on the car once the steering rack is off (that is related to it), or will just refurbishing it and putting back on buy me some extra road time without larger repairs?
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Think about the lower ball joints and drive shaft gaiters...Those joints will go at some time as water gets in.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- My Cars: Current:
Volvo V60 D4 180
Previous:
BX16RS (two of),
BX19TZI,
Xantia 2.0i saloon,
Xantia 2.0 Exclusive CT turbo Break,
Peugeot 807 2.0 HDi 110,
Renault Grand Scenic, 2.0 diesel (150bhp)
C5 X7 2.0 HDi 160 which put me off French cars possibly forever - x 16
Had mine refurbished last May and it was leaking again by Xmas. Just had it done again (under warranty thankfully) I hope this time it lasts a bit longer.
As for turnaround time, dropped it in to my local independent Tuesday morning for the rack removing and sending off for refurbishment and it was back with us Saturday lunchtime.
- Stickyfinger
AX, little Daffodil
- Contact:
Who did the referb ?
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
So I just want to make sure I get this right - this was a refurb from a used unit and not a Citroen Main Dealer new replacement? Reason being is Citroen are offering me another year's Extended Warranty for about £250. As I've already had my rack replaced with a new one under warranty - you can see why I went into cardiac arrest mode when you said yours started leaking again!Homer wrote:Had mine refurbished last May and it was leaking again by Xmas. Just had it done again (under warranty thankfully) I hope this time it lasts a bit longer.
- x 27
How do you think I feel after reading his statement regarding dual refurbishment ...GiveMeABreak wrote:As I've already had my rack replaced with a new one under warranty - you can see why I went into cardiac arrest mode when you said yours started leaking again!
Citroen only supply brand news ones to my knowledge.
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- Stickyfinger
AX, little Daffodil
- Contact:
£250 for a years extend is a DEAL.....I would as its a good bet for 4 hours labour at a dealer
....but check the small print about bushes/rubber parts and have the gearbox oil changed on the sneak
- x 27
Decided to try with the repair of the steering rack ... here's how it currently looks like
2 years warranty on the job, the price should be like the early estimate, 130 GBP ... and to add to that the required working hours for the rack taking out/putting back in activity ...
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
shame the pinion housing cant be replaced on it's own.. still a tricky job but that's the main issue VB? (plus a recon of the input shaft)
I guess there will be all of the seals inside it.. I remember once trying to rebuild one and I couldn't..
- Stickyfinger
AX, little Daffodil
- Contact:
That looks HORRIBLE !!!! .... who the heck designed that pile of poo....good job choosing a material that WILL corrode and destroy the seal.
How much movement is on the shaft...in/out ?
I am thinking a gaiter or the correct size could me obtained and fitted to avoid the corrosion ?
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
That's exactly how mine went before they replaced the whole thing. Bloody stupid design.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Went to get the C3 MOTd today and had a chat to my mate who is the Service Manager at the main dealer and asked him about the warranty - he said exactly the same thing - so will go for it for the piece of mind.Stickyfinger wrote:£250 for a years extend is a DEAL.....I would as its a good bet for 4 hours labour at a dealer
