Xantia 99 1.9 TD immobiliser problem - lexia results help needed
ecohouse1
My Cars: Rover 75 CDT TourerAuto , , Mercedes 190E 1.8 1993, 2CV6 Special 1987, Peugeot 206 1.1 2001. Repairs and maintenance of two Hyundai i10s
Deceased
Xantia TD Estate 1999 (now with Chris Morewood)
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
Renault Clio 1.4 Auto
GSA Pallas
Triumph Herald 1200
x 3
Re: Xantia 99 1.9 TD immobiliser problem - lexia results help needed
Post by ecohouse1 »
Thanks Jim, is the double relay the "smaller black thing" in with the ECU? And can I ask what the green relay does in next to the ECU? Sorry for the all the questions!
Cheers
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6156
Contact:
Post by CitroJim »
ecohouse1 wrote:Thanks Jim, is the double relay the "smaller black thing" in with the ECU?
yes, it is and the green relay is to do with the air conditioning Alan...
Sorry for the terse reply, very busy at the moment...
ecohouse1
Deceased
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
GSA Pallas
Triumph Herald 1200
x 3
Post by ecohouse1 »
Cheers Jim. Much appreciated. Alan
ecohouse1
Deceased
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
GSA Pallas
Triumph Herald 1200
x 3
Xantia TD Wiring Diagram Fault Finding
Post by ecohouse1 »
Hi Folks
Shivered my A** off prodding around the Xantia Electrics trying to get to the bottom of the immobiliser light and beep on ignition on. Reached the following conclusions:
Ignition on and plug removed from main engine ECU, identified:
No Earth present on 18 but OK on all other earth pins
No 12V supply to Pin 16.
From looking at the circuit diagram it appears that Pin 16 is fed from wire 1210 from Pin 5 on the Double relay? 1304
What is component 1208 at the bottom right?http://s1038.photobucket.com/user/ecoho ... sort=3&o=0
Many thanks
x 6156
Contact:
Post by CitroJim »
When I'm home I'll be able to see, on Tapatalk on my phone at mo and can't see the diagram in any detail..
superloopy
My Cars:
x 18
Post by superloopy »
Haynes BOL identifies 1208 as 'Diesel fuel injection pump(advance corrector, electric cut-off, safety switch)' .... Jim'll have more to add soon :wink:
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
ecohouse1
Deceased
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
GSA Pallas
Triumph Herald 1200
x 3
Post by ecohouse1 »
Mmm that's interesting - could that be connected to the immobiliser? Also does anyone know where MM01 earth point is? That's the wire M132B attaches to from the ECU pin 18.
On saturday I cleaned up all the inner wing earth points next to the battery, the main earth on the gearbox attached to the battery neg and also the 10 ml bolt head earth on the N/S Chassis leg just forward of the gearbox. Have I missed any other earth's?
When I pulled the corrugated plastic shielding off the ECU loom as it crosses the O/S engine mount, it all crumbled apart! Struggling to read the numbers on the thin wires!! Will need to resort to a magnifying glass.
If I was to run a temp bypass wire to earth on M132B, would I just bare a bit of insulation and attach a croc clip wire as access to the ecu plug itself is difficult?
Cheers
KennyW
(Donor 2022)
My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate
x 132
Post by KennyW »
Alan,
I think it is located on the inner wing and you have said you have cleaned up the contact.
I had a similar problem on my TD a few years back and it was one of those pesty connecting blocks smply bypassed same and it ran with no problems.
I'll check through the old thread and check.
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
ecohouse1
Deceased
Xsara 1.9D Saloon
BXTZD Break
BXTGD Hatch
Peugeot 309 1.9D
Various 2CVs
Porsche 924 lux
Porsche 924S
GSA Pallas
Triumph Herald 1200
x 3
Post by ecohouse1 »
Thanks Kenny, can you remember the connector responsible. I can try that next!! Cheers
Post Reply
