Right update, it seems I was mistaken about where the goings on were going on.. the 'relay noise' and arcing seems actually to be inside the door itself and is, I am sure, the control unit for the one touch driver's window. Basically I can hear an occasional 'fluttering' of a relay in the door. The supposed arcing I saw was no such thing it was the blue light from an after market turbo boost gauge fitted in the space below the switches for the fogs/ alarm/ rear windows override. It is only a sound, not a visible spark.
As an aside, the driver's window is now sometimes failing to respond to the button. Pressing it a few times sees it spring to life.
I think a power feed to the control box is bad. Will investigate at the W/E
xantia mk1 electrical worry
- Donor 2023
- Lexia Available: Yes
- My Cars: 2008 C5 Exclusive Tourer
1993 Xantia 1.9 TD VSX Mk1 Sinker A.K.A Slugmobile 13'
'Old Katy'
previous convictions: totaling 52litres of LHM in one go:
1968 ID19B 'Old Polly' Stellar white
1993 Xantia 1.9 TD SX Mk1 Sinker Silver
1992 XM 2.0 SEi Turbo Manual Anthracite Grey
1982 CX 20 Pallas 'Old Goldy'
1993 XM 2.1 SD Auto Light blue
1993 Xantia 1.9 TD SX Mk1 Sinker light Blue
1982 BX 16 TRS 'Cyril' Vallelunga Red
1995 Xantia 1.9 D SX Auto Dark green
1977 CX 2400 Pallas C-Matic 'Aphrodite' Regatta Blue
1982 GSA Pallas SE Silver Pearl
1980 CX 2000 Reflex Vallelunga Red
1978 CX 2400 Pallas C-Matic 'Prometheus' Midnight blue
1984 BX 14E 'Cecil the slugmobile' Maroon
1987 Fiat Panda 'the mighty panda' - x 97
Re: xantia mk1 electrical worry
Graeme M
- My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny! - x 66
- Contact:
Good that you've made progress.
Not familiar with the setup, but chief suspects must be either damp/corrosion in a connector inside the door, or something in the wiring loom through the door has fractured due to age/constantly being worked back/forth all these years.
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
Iain
- Donor 2023
'Old Katy'
Yes its definitely the one touch relay that's going loopy. It just buzzes intermittently and the window will not move in this state. Passenger window is fine
Graeme M
- Donor 2023
'Old Katy'
Well, I had a closer look at this and found that the control box of the one touch driver window was buzzing crazy style. With the cover removed and reconnected to the block connector the two little relays in the unit were fluttering like a pair of noisy electric moths. No sign of any bad bits on the solders of the control box 'board and no visible issues of connections at the block connector either. I think the problem is with the control box itself. Switch eliminated and supply voltage eliminated. The control box was only just replaced! Well, I refitted the bridging wires I had used before to eliminate the control box and let the window go up and down via the switch albeit with none of the 'one touch'.
It's working very well for a few days now so I'll probably just keep it like this
Graeme M
