No need for programming the instrument panel on a Picasso.Stempy wrote:Not really that much of an expert, maybe a Lexia session would show something up. You could at least measure the signals from the sensors. It's possible that a replacement instrument cluster wont work without being matched to the vehicle.
Fitting a virgin BSI to a C5 SORTED
Re: Fitting a virgin BSI to a C5 SORTED
- My Cars: Renault 14...now skyward
Renault 19.. skyward also..
'03 Xsara 1.8 Picasso in silver met his maker
'06 Desire, again in silver also gonn to metal heaven
the display unit IS compatible with the car, all else works........... the sensor change /diagnostic cost me over £130, and was suggested he could "put the problem right" for getting on for another £500.......................by swapping the bsi.....or maybe the ecu as well.......diags, just shows something like speed sensor fault.....
2nd opinion agrees that the sensor is not seen........but sensor wiring is ok
edit
the instrument/radio panels haven't been interfered with, no kiddie trouble, otherwise the car runs like a dream, obviously have no live consumption figures......just full-empty estimated Mpg, which isn't far out........
edit
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
As an update on previous questions and issues I have discovered that my C5 has variable PAS which uses a mechanical pump and is controlled within the BHI. I used the Lexia to test it today and it's working fine.
The fault on the front height corrector seems to have been a poor connection at the sensor. I unplugged it, cleaned the terminals and replugged. Cleared the fault on the ECU and it's been fine so far. The aircon is now fine bar the external mirror sensor which has been ordered, after clearing the blower fault it hasn't returned.
The only faults left now that I'm not sure about are on the instrument panel which tells me that engine speed, vehicle speed and coolant temp sensors have returned an incorrect value, and states 'fault caused by another ecu', and the alarm which says the ultrasonics are duff so I guess new transponders would sort that out.
Also, I wonder if anyone knows why the speed related volume adjustment doesn't work? It never has so maybe it's not an option, but it is in the radio menu and there are several 'laws' you can progamme it to in the Lexia. And the radio also shows a permanent fault at the aerial input, no idea what that's about as it works perfectly well.
Lexia ponce
Lexia ponce
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
I recall a post where somebody found that the soldering within the sensor was an issue, as the pins are square and the holes (on the circuit board) are round, and somewhat lacking in solder. I know that I mentioned it (and had a link) in trainman's thread.
I have the same issues with the instrument panel and the aerial (apparently water can get into the aerial base and cause some grief).
EDIT; Found the link. The photos aren't there any more, but the text explains it very well;
http://www.frenchcarforum.co.uk/forum/v ... 9&p=356736
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Do you know where the sensor is located? Is it a sensor that is just for the radio?
Lexia ponce
Lexia ponce
- Donor 2023
- x 2993
I was on about the height sensor. Sorry I didn't make that clearer.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Damn, my extra sensory perception failed again.
Lexia ponce
Lexia ponce
