Reinforced clutch just arrived today.
It will be replaced next week. I' get back and make some report.
1.6hdi clutch flywheel or solid ??
- Romzi
- My Cars: C5 break II, 2.0 HDI
- x 3
Re: 1.6hdi clutch flywheel or solid ??
Done!
Clutch replaced. The old one had some signs of wear, but nothing significant.
The old DMF was still completely fine after approx. 100.000 km (62 000 miles), just I suspected. It was replaced of course, too much work and way too much money to do it again.
The new clutch is completely different. Reinforced pressure plate, but softer on the pedal ( ). It has that nice filling in the middle, when the pedal just soflty dives to the floor. Like it should.
Previous one (LuK clutch + dmf kit) never felt like this. The biting point was also somewhere at the top.
If it will last, only time will show. I hope so.
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1380
Just remind me. Is this the solid flywheel clutch kit or replacement DMF with solid clutch friction plate kit?
- Romzi
- x 3
DMF + solid clutch friction plate (uprated Sachs clutch). Look at Sachs Performance.
- jsp
- My Cars: AX 3x 10E 1.4 GTI 5drs 1.0i
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
1994 AX 1.4 5dr TGS GTI
1994 AX 1.0 3dr Escapade
1996 AX 1.1 3dr spot Burgundy
1996 AX 1.1 5dr Verte
2003 peugeot 206 xs leather with auto A/C - x 12
I have recently fitted a SMF Valeo kit4p on one of my friends C3 2011 1.6 Ehdi. I bit juddery on the low rpm besides that completely fine. I don't know why this DMF was in the first place. All the old diesels I had had Single mass flywheel some of them made huge tq on stock engines without any problems. Or are the new generation weak engines with weak crankshafts?
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
No, they are more powerful engines and produce more torque, so more torsional stress.
Jsp thanks for the feedback. Do you have any feedback on the life of the Valeo 4P clutch plates. Any feedback from your clients? Especially for the C5 2.0 136 16V engines.jsp wrote: ↑12 May 2020, 02:36 I have recently fitted a SMF Valeo kit4p on one of my friends C3 2011 1.6 Ehdi. I bit juddery on the low rpm besides that completely fine. I don't know why this DMF was in the first place. All the old diesels I had had Single mass flywheel some of them made huge tq on stock engines without any problems. Or are the new generation weak engines with weak crankshafts?
On the 8v 109 2.0 HDI engines in Xantia, which were very similar there was no DMF. So I am not so sure if the DMF is really needed.
Were the low rev "judder" you mention significant? at what revs did you notice them?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
yes little juddery but, reliable
My Citroens update:
