@Ben . Copper (as u say) or Silver is the way to go on plugs, Iridium etc is for longevity not performance.
As to them gauges - u won't see me having them on the A-pillar - looks very teenager like and distracting (to me). The AF and boost gauges are more or less there to verify that everything is OK, and is not something i usually check much during drive other than at a glance like when u check the rear view mirror. I am aware of how little distraction it takes to make a mistake, that is why i am very careful when texting and driving.
Bergen Xantia Activa CT
- x 443
Re: Bergen Xantia Activa CT
Moving off the subject of boots gauges...
Your car is a series 2 so has an immobiliser chip in the ignition key. The antenna ring around the ignition lock sometimes gives trouble.
- x 6
If I understand u correctly v6, u think my antenna ring around the ignition switch might be faulty and cause my engine to run bad or not at all ?
- Donor 2016
- x 735
EMails are a bugger at speedHansNOR wrote:I am aware of how little distraction it takes to make a mistake, that is why i am very careful when texting and driving.
- x 443
It can cause it to run not at all, but I think it also brings on a warning light (I have not owned a series 2 Xantia for several years).HansNOR wrote:If I understand u correctly V6, u think my antenna ring around the ignition switch might be faulty and cause my engine to run bad or not at all ?
- x 1702
Yes Mike, that's correct. If the aerial is duff the engine won't start and ill illuminate the yellow warning light that looks like a three-side box with an arrow in it...
- x 6
Dont think there is such a warning light. But airbag warning light came on ... :p hopefully bad connection under the seat
- x 1702
If you're not seeing it Hans then all is OK on the immobiliser... I think the light is in the tachometer and is in the same position roughly as the door-open warning light...
Occasionally you see it flash briefly when you first turn on the ignition but not always..
- NOT Alistair or Simon
- x 1285
Assuming you do not have a blown light bulb (if it is, replace them all in one go, as it saves having to replace another one in six months time!), the immobiliser light is on for less than a second. Pop the key in the ignition, look in the main instrument panel area, and turn the key. White box, key symbol in it, and if you blink you will miss it.
- x 1702
James, that's excellent
Your memory is better than mine
