Why won't my Activa talk to Lexia?
wurlycorner
My Cars: Two C5's...
Lots of CXs...
A couple of Xantia...
A C2...
Lots of Prelude's...
And a Sunny!
x 66
Contact:
Re: Why won't my Activa talk to Lexia?
Post by wurlycorner »
Ah... One of those...
Iain
1x '85 CX GTi Turbo s1 (metallic blue)
2x '85 CX GTi Turbo s2 t1 (metallic silver & grey)
'88 CX GTi Turbo s2 T2 (metallic light blue)
CX DTR T2 Safari (silver)
2x '96 Xantia Activa (Black & metallic green)
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1289
Contact:
Post by Stickyfinger »
Brain is shorting out trying to remember the name of the earlier Citroen reader :).............nope....nothing ....its a "Jim's special thingy" sort of thing.
ELIT ! (?)
got there :)
Activa, the Moose Rider
3x C5x7 Steering racks and counting
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
ELIT, yep, that was before LEXIA.
My lead doesn't match up with this chinese pin out for the harness, either...
Mine has the following, which that doesn't - B2, C2
That has following, which mine doesn't - C1
What a bloody pigs ear...
Iain
AX, little Daffodil
x 1289
Contact:
Great init ..........European "standards" in the 90's.....love'em :)
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
There's a lovely load of genuine Citroen diagnostic equipment here (including at least one full complete LEXIA machine)...
http://www.ebay.de/sch/sis.html?_nkw=AC ... 7675.m4099
Unfortunately none of it is at DIY price!!!
Iain
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 833
Post by xantia_v6 »
30 pin diagnostic socket connections (from Citroen documentation):
Note that not all pins shown are used on the Xantia, but I think the relevant ones are in the right place
Check that the 12V is present on A1 and A2
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6176
Contact:
Post by CitroJim »
H1 (crusie control diagnostic) is interesting... The old Hella vacuum cruise was never diagnosable so I wonder which one that is?
Iain, as said in the other thread, i have a known - goof 16 to 30 adaptor here and I could buzz that out.. You can then see which of the 30 pinouts map across to the 16 pinouts...
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
Thanks Jim,
I hadn't seen Mike's previous reply - looks like that thread might include the necessary information on pin-outs (and it confirms that the plug pin references are mirror image - so I guess the numbering is when viewed from the back of the plug, rather than the face) if you could also please bell out your known working lead and post here though, that would also be appreciated.
Mike, thanks for finding the other thread!
Iain
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
Right, going on this set of pin identifiers;
From this post
My lead bells out as follows;
Which is different in many regards to the lead in the post above, although the battery live, injection ECU K and Injection L lines match (which is the ECU I'm most interested in at the moment) and the chassis ground matches to one of the pins (thought I have a second pin).
I don't know what car that was successfully used on though (I'll pm Mandrake to see if he can advise further) so it would be good to see what your lead looks like please Jim, if that works on an s1 Xantia/Activa...
Iain
x 6176
Contact:
Post by CitroJim »
Give me an hour or so Iain and I'll buzz mine...
Both permanent live and switched live supplied are needed and in theory, as long as those are there and the K and L lines from the engine ECU are correctly mapped you should see the Engine ECU...
Have you confirmed your Lexia works OK on another car with a 16 pin socket?
Are you selecting the engine type as 'RGX' with MP3.2T Injection when trying to run a diagnostic?
x 6176
Contact:
Post by CitroJim »
Iain, using your notation in your pictures above, here's my buzz-out of a genuine Actia 16 -30 adaptor as originally supplied with my Lexia 2...
30pin 16pin
A2 1
G1 2
I2 3
A3 4
N/C 5
E1 6
C1 7
F3 8
H3 9
I1, I3 10
E2 11
E3 12
D2 13
F1 14
C2 15
A1 16
Hope that helps and it looks a bit different to yours...
Checked twice to ensure accuracy...
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
Thanks Jim. Definitely some differences in the wiring there then!
I've updated my pin out's scribbling as a back-back comparison (hence the crossing out to move I2/I3 down a line!);
Crosses in the middle indicate where there are changes.
However, I have made some progress...
Checked the fuses and the layout in my fusebox isn't the same as the one I'd seen on the forum, i.e. F2 being the diagnostic socket fuse.
This is in my cars handbook;
So checked F15 and...
#-o :oops:
Of course the spare fuses slots were missing, the local garage had run out of ordinary sized blade fuses, the C5 didn't have 10amp in that size... So I robbed them out of the DTR sat on the drive :oops: poor thing
So, with that replaced, all sorted right? [-o<
Well yes, it was a lot more promising - when I set Lexia off to do the diagnostics, it took a long time to run through the dialogue screen, instead of racing through it. The PCI box also had relays clicking this time (I don't recall it doing that last time on the Xantia, although it did on the C5's, so that should have rung some alarm bells really)
Ah, but if only it were that simple...
So we have communication with the injection ECU but the others are a no-go.
I'm going to stick with this being down to the 16-30 pin harness being wired incorrectly, as suggested earlier - looks like the injection ECU lines are correct but all the others ECU lines are wrong :evil:
I'll contact the seller to see if they can offer any help with alternative harnesses and will update the thread accordingly when I have any progress.
At least that does cover the most critical one at the moment though - I have the pin outs for the ABS ECU plug, so I can bell out the ABS sensors from there (again...) to find the latest offender.
Thanks all for their help on this.
Iain
x 6176
Contact:
Post by CitroJim »
Excellent Iain :D I've been caught out by the lack of both supplies to the diagnostic socket in the past, and to the subtle differences in fuseboxes too..
I see the ECU prima-facie appears clear of faults but it's still worth going in and looking to see if any stored faults are present which there will be if the EML was on...
You need to get hold of a 16 pin OBD plug and a socket and make up a patchboard between them so you can experiment with wiring until it all works properly!
wurlycorner
Lots of CXs...
A C2...
And a Sunny!
x 66
Contact:
CitroJim wrote: I see the ECU prima-facie appears clear of faults but it's still worth going in and looking to see if any stored faults are present which there will be if the EML was on...
Ah... I will update the cars profile thread with further progress :wink:
Iain
AX, little Daffodil
x 1289
Contact:
Your doing great work there sorting these out, I wait your next instalment.
Post Reply
