Ever sheared off a bleed nipple?
x 1779
Re: Ever sheared off a bleed nipple?
Unread post by Stickyfinger »
can that pick up New York ?
x 7407
Bet they don't play Rock'n'Roll.... :wink: :)
chinkostu
x 30
Unread post by chinkostu »
I sheared one off a beetle front cylinder. Ended up bleeding it via the hose.
the whole car was rotten mind :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 5308
Someone had put a bolt in the bleed port on the front of my Renault 14.
Spent ages removing it, tapping it out and fitting a larger nipple.
Why I didn't just get another calliper from a scrapper I will never understand.
x 7407
myglaren wrote:Someone had put a bolt in the bleed port on the front of my Renault 14.
A well-known bodge back in the day... A kind of bleed could be achieved nu loosening the flexi hose at the caliper end and letting fluid bleed from it...
Not good :twisted:
Zelandeth
x 1508
Unread post by Zelandeth »
Only once have I had this happen to me (so far) and it was on the clutch slave cylinder on my Lada Niva. Wasn't worth trying to sort the cylinder (new one was £12 delivered), but it took me a week to find time to fit it - during which time I just made do with no clutch!
Still remember it feeling rather odd being able to do a job like that which involved laying under the car but not having to jack it up...
Current fleet:
07 Volvo V70 SE D5, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
x 7407
No clutch for a week Zel? Amazing! How?
x 1779
Drove to Devon in an Austin Cambridge .....good old days with good old gearboxes............ Match it and ram it in Jim :)
x 7407
Stickyfinger wrote:Match it and ram it in Jim :)
Never managed to master that technique Alasdair :( Tried a few times years ago and failed epically every time...
x 1779
Persistence, youth, ignorance to the possible damage and not being worried about the box helps :)
chinkostu
x 30
I find it far easier rev matching up the gears than down! The box does help!
Never tried it clutchless though
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 7407
Stickyfinger wrote:Persistence, youth, ignorance to the possible damage and not being worried about the box helps :)
That was always my big worry...
Seriously, clutchless changes on a BE3 'box can kill their [delicate] synchros very easily.. Many a BE3 has suffered this fate due to a broken clutch clip....
Donor 2023
x 3190
I remember when I had a clutch problem on my first car, the BX 19 TZD. Changing gear on that was getting very tricky, especially first gear. Turned out it had one of the older design of transfer lever (you know, the "L" shaped that then pushed the final external linkage). Well, I went down to the scrappy (my local Citroen dealership had micked me off when I asked if I could get an owners' manual, and some smartarse had said he didn't know owners came with manuals!), and found a newer BX, got the lever, rod and bolt off it, and swapped them over. Problem solved, and the clutch felt a lot lighter.
daviemck2006
x 494
Unread post by daviemck2006 »
I do clutchless gearchanges most of the time going up the box, and about 1/2 the time coming down. Don't matter if it's a car, van or bus, fwd or rwd. When you have sciatica in the left leg there's sometimes not much option. I've never knackered a gearbox yet!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Citroen dispatch 2014
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
x 7084
Now members of the clutchless club, imagine a busy roundabout ahead.......lets say the Whitemare Pool roundabout for example, and you have done the relatively simple task of driving 30 odd miles without the use of a clutch....probably only a handful of changes necessary... in a dagenham jelly mould....What do you do when you have to stop?
and how do you start off again? Tricky especially from the flat or slightly uphill, and of course there is the added pressure of possibly reducing the entire road network to a standstill by breaking down right on the roundabout in rushhour traffic.
Well it probably, or should I say definitely, doesnt do the starter much good-but you can become quite an artist at the controlled starting in gear lurch, and pick up the revs to avoid the stall, and off you go heading for the next series of matching revs clutchless changes.
Yes in summary, complete lunacy should have just pulled in where it was safe and called the AA and turned in late.
regards Neil
