the middle one looks almost alien!
thanks for the links VB but i dont think they would be upto the pressure im looking for as they all look to be low power units mainly for transfer of fluid between drums or such like
C5 Hydraulic pump flowrate
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: C5 Hydraulic pump flowrate
Arrggghhhh! The Cybermen are coming!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1290
- Contact:
Come on KP.....what's this "project" all about ?
Activa, the Moose Rider
3x C5x7 Steering racks and counting
I'll spill when it's all working but could be a wee while
Whatever you use, a rough calculation suggests that it will draw about 20A at 12V, so you'll need fairly hefty cable to minimise volt drop.
- Stickyfinger
AX, little Daffodil
- Contact:
Not a good answer, I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to know I want to knowKP wrote:I'll spill when it's all working but could be a wee while
You can wait fella
- Stickyfinger
AX, little Daffodil
- Contact:
aggg.....another 10mins on the naughty step !
Ha ha ha more time on the naughty step means a longer wait.... :p
That's the way to tell them KP. I hope it works as well for you as my one did when I built it last year. I did have a little trouble with clumping in the agglomeration but I overcame that. Your plan probably bypasses that stage. Good luck.
The pump and tank attached will be the highest part in the system so I'm hoping I can easily bleed it just through pumping it for a little bit and then leaving it a day or two and then same again over the course of a week or two
