I just bought today a Xantia 3.0 V6 Exclusive
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 833
Re: I just bought today a Xantia 3.0 V6 Exclusive
Post by xantia_v6 »
kentc5 wrote: I will book her for timing belt replacement ...
Would that do to order?
http://www.eurocarparts.com/ecp/c/Citro ... 5d2&000332
Garage quoted 5hrs labour more less.
When they do the timing belt they will have a closer look of the suspension pump as well.
That is the correct timing kit, but if your engine still has the original style timing belt tensioner, then the later (better) tensioner illustrated in that kit will not fit unless the water pump is changed for the later style (or modified).
If ordering a water pump do not order the original type for the car (as it will also not fit), but order one for a 2000 year Xantia.
The earlier pump can be made to fit with the new style tensioner by cutting the ear off the pump with a hacksaw (but your garage might not be too keen on that operation).
5 hours is a reasonable time for someone who knows what they are doing with the right tools. My first took 10 hours, and I have done one in less than 4 hours.
kentc5
My Cars:
Post by kentc5 »
Well ... I am going according that the timing belt has never been changed on this car...
therefore I assume it has all the original bits...
So to understand for this kit to fit properly it needs a 2000 style waterpump eitherwise it will not fit?
edit... I just noticed the kit does not include the waterpump
Will that do me?
http://www.ebay.co.uk/itm/Citroen-Xanti ... XQ3kNTe3F0
Current Cars:
Citroen Xantia 3.0 V6 Exclusive ('98)
Alfa Romeo 166 2.0TS ('03)
Audi A6 C6 2.4 V6 SE ('05)
BMW 735i Individual M-Pack ('00)
Lexus GS300SE Navigator ('98)
Toyota Prius T-Spirit ('04)
furriegurrie
My Cars:
x 24
Post by furriegurrie »
You'll need to cut off the big hole on the right to fit with the new tensioner...
My Cars: -
x 833
Post by xantia_v6 »
kentc5 wrote:Well ... I am going according that the timing belt has never been changed on this car...
Will that do me?
That is the original style pump that needs the lug cut off. They are now cheaper than the later style, because few people buy them and there are a lot of old-stock ones floating around.
kentc5
My Cars:
Post by kentc5 »
Sorry to be a pain...
so if I buy this one (seems to be the new style)
http://www.ebay.co.uk/itm/FWP2176-FIRST ... SwyQtVtkIm
And the timing belt kit...
There will no modifications needed and everything will fit in properly :)
Current Cars:
My Cars: -
x 833
Post by xantia_v6 »
kentc5 wrote:Sorry to be a pain...
That looks like the right one. No modifications should be needed.
kentc5
My Cars:
Post by kentc5 »
ordered the pump and should hopefully book the garage for the end of next week :)
Current Cars:
kentc5
My Cars:
Post by kentc5 »
OK so the car should be back today... from the cambelt...
Now regarding the second LHM leak from the pump.... it appears to be from the pulley?.... can this pump be fixed? or do I need to start looking for a replacement one? :( ...
They haven't taken the pump out but they had shown me it is all freshly wet around the shaft...
Is it safe to be driven like this until it is fixed... ?
Current Cars:
My Cars: -
x 833
Post by xantia_v6 »
It depends how much LHM it is losing. A few drops should not be a problem.
The pump can probably be reconditioned.
kentc5
My Cars:
Post by kentc5 »
well as you can understand it loses when it is driven... rather than stationary.
When I drove for almost 300 miles the other day. It lost that much I did not even need to top it up.
Current Cars:
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1289
Contact:
Post by Stickyfinger »
Leaking HP pumps will kipper the alternator quite quickly as it (normally) drips down on it.
I have a "spare" referb one just about to come back to me for fitting to my Activa.....we could maybe work something out if your needs are urgent.
(I have PM'd you my phone number)
Activa, the Moose Rider
3x C5x7 Steering racks and counting
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6182
Contact:
Post by CitroJim »
Get in touch with Martin at Pleiades for reconditioning and advice... He's done an excellent job on a few V6 pumps for me over the years..
Leaking from the shaft is quite unusual in my experience...
x 6182
Contact:
Post by CitroJim »
Stickyfinger wrote:Leaking HP pumps will kipper the alternator quite quickly as it (normally) drips down on it.
Yes indeed although if you get them off and give them a good clean with gentle electronics solvent and compressed air they survive..
I've treated several very wet ones now and they are still good...
The secret is to remove them though...
kentc5
My Cars:
Post by kentc5 »
I got the car back from the garage and the engine is so quiet now !!! :) smooth and perfect gear changes :) (well it had that before) .But now the whole thing clicks good in place :)
The mechanic who took it out for a spin after the work was done to test drive. Did say he has never come across to a Citroen that smooth and quiet engine and so smooth gear changes before. He was really surpised :)
I have noticed that when revved (stationary and in P) to 4000 rpm the engine will vibrate like something is out of balance?... the vibration does not happen above those revs or below those revs...
could that be the shaft of the LHM pump?...
Current Cars:
My Cars: -
x 833
Post by xantia_v6 »
Check the top donut engine mount and the rubbers on the stabiliser bar nearby, if these rubbers tear (and they do) any slight movement in the engine can be amplified.
It is possible that you have a misfire due to a faulty spark plug or lead, but that would normally be more evident under load.
Post Reply
