I've ben wondering how to 'repurpose' a hand blender. The motor bit is OK but the bearings for the knife/impeller are stuck.
Sadly the metal is too thin for an incinerator Steve, I thought about a hamster gymnasium or maybe fit a crank and use it as a compost mixer, but I suspect it will go to the local recycling centre if SWMBO gets fed up with it on the patio awaiting my attention. The motor and bits I've secreted away but no room for the drum!!myglaren wrote: 14 Oct 2020, 18:43 And you can make an incinerator from the drum!
Maybe i misunderstood but are you saying SWMBO does the leaf/debris catching/clearing ATM so she would approve of less work to domickthemaverick wrote: 14 Oct 2020, 19:36 Good thinking bobins, I have been toying with a leaf/debris catcher in my subterranean pond where the waterfall flows in, to keep the rest of the pond clear, that may be a use which even SWMBO will approve of!![]()
No she doesn't do the cleaning, another of my chores, but she does get irritated when the waterflow is insufficient for the waterfall to twinkle and the cause is usually a partially blocked pump inlet!admiral51 wrote: 14 Oct 2020, 21:03Maybe i misunderstood but are you saying SWMBO does the leaf/debris catching/clearing ATM so she would approve of less work to domickthemaverick wrote: 14 Oct 2020, 19:36 Good thinking bobins, I have been toying with a leaf/debris catcher in my subterranean pond where the waterfall flows in, to keep the rest of the pond clear, that may be a use which even SWMBO will approve of!![]()
Dug that up from the archives because today I didnt manage to get the camera out quick enough to snap another blue iconic bike from the 1970's. A blue Honda CX500.....when was the last time you saw one of thoseNewcastleFalcon wrote: 17 Oct 2018, 15:54 side by side a 68 reg strange looking machine with double front wheels, and a motorbike
