x 2841
CitroJim wrote: 04 Dec 2018, 06:47
Hell Razor5543 wrote: 03 Dec 2018, 18:56
CitroJim wrote: 03 Dec 2018, 17:50
The train was stopped due to a couple of leaves on the line at the time :lol:
Ah, that is how those Nissans get recharged in the middle of nowhere! They nick power from Network Rail!
Nice one James :rofl2: :rofl2:
You might be joking but I wouldn't mind betting that it will be tried. I posted before about the guy on our estate who was running his domestic electric from the street lamp with a cable trailed across the footpath.
x 7405
Gibbo2286 wrote: 04 Dec 2018, 10:34 You might be joking but I wouldn't mind betting that it will be tried. I posted before about the guy on our estate who was running his domestic electric from the street lamp with a cable trailed across the footpath.
:shock:
Mind you, anyone trying and succeeding at charging a Leaf from the 25Kv Railway OLE deserves all the free electricity he can get :twisted:
But if he succeeded, would his Leaf be forever late and demand it needed to have a driver and a guard on board at all times :lol:
Along with a destination board on the front!
x 1326
Those that have been around a while will know that I have a memory for, and a like of, random number facts.... Mallard is no exception! It's LNER number is 4468, which is the same as my extension number was when I worked in Reading - a job I left nearly 18 years ago.....!
x 7405
RichardW wrote: 04 Dec 2018, 13:20 Those that have been around a while will know that I have a memory for, and a like of, random number facts....
You and me both Richard :D
Keep 'em coming ;)
x 1757
Andalucian morning
View south from our terrace, 0800 this morning, and total cloud cover over the Med out to the horizon, as the sun was about to come up.
The hilltops poking through are about ½km from the shore.
x 3339
Meanwhile at work today...... I've had to open extra sluice gates in the mill pond to stop it overtopping with the deluges we've been having. Have a guess where I'd rather be :roll: :lol:
x 1222
Unread post by Peter.N. »
Oh I would love a mill - free electricity 8-)
x 1757
Peter.N. wrote: 07 Dec 2018, 11:52 Oh I would love a mill - free electricity 8-)
Me, too.
There must be some wind in Dorset, Peter. Nothing personal, of course :wink:
x 1222
I used to have a wind turbine Chris but it fell down a year or more ago, as the batteries were beginning to fail I didn't repair it. It ran a lot of the time here but was only an emergency supply. We rarely get power cuts but it has been called into use on a couple of occasions when it ran all the essential house functions for a number of hours without problems but batteries are to expensive to only be used occasionally.
I have a small standby diesel generator but that still has the original diesel in it.
x 1757
A diesel generator - what a good thing to have! When we moved here 15 years ago, electricity supply could be somewhat unreliable: several very short interruptions each day (maybe for up to a minute each), plus some longer ones. Voltage (supposed to be the EU standard of 230) could wander down towards 200 quite regularly, and even dipped to 170 on a good few occasions - at which point 'fridge motors don't rotate, they just vibrate :( . Worst outage was 5h one Christmas day, with several of the family from UK here. Since those days, and the national generator Endesa being taken to court and heavily fined for the quality of their service in Andalucia, things have improved no end; maybe we see a two or three cuts a year, usually for scheduled maintenance.
So, from the word go we bought a backup generator. Ended up with a 2500VA Honda petrol at around €300. Anything diesel was five times that, although usually twice the output. While doing a bit of building work, we created a brick-built fire-proof cubby-room for it, accessible from the garage under the house, and with a 42mm exhaust run to outside, air in and fully extractor-vented. A 3-way changeover switch was installed next to our consumer unit, so that the main phase for the house could be flipped from normal to generator, as is legally required.
Petrol isn't the best thing to leave sitting for months at a time, years 'in the can', but it seems to last ok these days. The Honda always starts 3rd pull at worst, which is why we opted for it. It did the 5h Christmas duty, and has done a few of "all day" outages as well.
Early on, after a power cut, we got a phone call from a neighbour on the other other side of the valley, letting us know that grid power had been back on for half-an-hour . . . :oops: . We soon added a switchable beeper to the consumer unit to alert us to the main supply returning!
Did once idly wonder about an XUD coupled up to an alternator . . . :-k . . . probably a bit OTT.
x 1222
Would provide plenty of power but you would need a big alternator to take advantage of it.
This generator is only a cheap Chinese one that I bought secondhand so I didn't pay much for it. It has electric start but doesn't start well in cold weather without a squirt of Easy Start, then it goes fine. Its only about 2kw but all I really need is one that will provide enough power to pump the water up.
We have a well at the bottom of the field and a 500 gallon tank at the top so it has to lift it 25' from the bottom of the well and then pump it another 60" or so to the top of the field, then gravity fed to the house. Once the tank is full it will last 4 or 5 days or in an emergency even more. If the pump packed up we didn't know about it until we actually ran out of water but I have installed an early warning system, a Watchman wireless oil level indicator so we can check the water level from the kitchen. I installed it about 2 years ago and nothing has gone wrong since.
Yes, an early system is what you need, we just look out of the window and see if the lights have come on at the farm.
x 7084
Nasa have an image of the day, as does geograph...and also http://www.oldclassiccar.co.uk/ which is an interesting site for a peruse (I often use it for its reg no info)
Today's offering is a nice 2-tone Austin A95 Westminster
regards Neil
x 7405
I like that Westie :D
x 1222
A friend of mine had one. Very quiet engine wise, you could hardly hear a good one ticking over, nice interior too, just a bit thirsty.
x 2841
Peter.N. wrote: 10 Dec 2018, 22:14 A friend of mine had one. Very quiet engine wise, you could hardly hear a good one ticking over, nice interior too, just a bit thirsty.
Still on drum brakes that quickly faded if you used the power, quite frightening at 100mph when the brake pedal is solid and you just keep going faster. :shock:
