Lower suspension joint/bearing made my car do that.....later I got a "click" on tight corners at low speed.
I felt unhappy with the steering (felt loose) for weeks and kept saying there was something wrong (even if it had just past it's MOT).
They had collapsed totally.
Should I change my spheres?
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Re: Should I change my spheres?
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- waynedance
- x 8
What bearings do you mean, front lower ball joints? Are there any top suspension mount bearing like on regular spring cars?
Sent from my LG-H815 using Tapatalk
Volvo S80 D5.........
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
I think Alasdair does indeed mean the hub ball-joints.
There are no top suspension bearings, the whole strut outer and hub rotates about the inner strut shaft which does not rotate. The top of the strut shaft is supported by the infamous Xantia Strut Top/Mount, these do give trouble but not with the symptoms you describe.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- waynedance
- x 8
May change the ball joints as they are not expensive. I have the tool somewhere to remove them.
Do not here any knocking down pot holes like you would think if the ball joints had excessive play.
- Stickyfinger
AX, little Daffodil
- Contact:
Yes I do....sorry my terms got all mixed up.
I had no knocks either, just a "loose feeling) on changing direction then later the click and it looked like this when it came apart.
I have drive American cars (new ones btw ! ) with worse steering than this had in this state
http://www.frenchcarforum.co.uk/forum/v ... ts#p439219
- waynedance
- x 8
Not got thoses on C5?
- Old-Guy
From the service.citroen parts diagram the C5 has a fairly conventional bottom swivel ball joint that appears to screw into the hub. It looks as though a special tool is needed to undo/tighten this.
- waynedance
- x 8
Got the ball joints and tool will fit this week.
- Stickyfinger
AX, little Daffodil
- Contact:
Ahh....not an x7 type....then yes,the same screw in ball type.
- waynedance
- x 8
Not long now until the 6 new spheres arrive.
How hard is the front middle one to change? Looks tight.
