Nothing on the MOT about that, neither this one nor the previous ones. I didn't know that until I started working on the brakes.RichardW wrote: Did they not even warrant an advisory on the MOT?
Xsara Pic MOT failure for brake and exhaust
Re: Xsara Pic MOT failure for brake and exhaust
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
1985 2CV6 Special
Yeah that's shocking. I will have to have a look at the front brakes myself...Hope everything is fine.JohnD wrote:That brake hose is shocking not to have had an advisory even at last year's test.
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
- My Cars: Renault 14...now skyward
Renault 19.. skyward also..
'03 Xsara 1.8 Picasso in silver met his maker
'06 Desire, again in silver also gonn to metal heaven
I guess that the auto adjust on the rear brakes, is done by handbrake pull? how many H/brake clicks is the normal? On Mine one click brake is on, two clicks its REALLY on......
MOT re-test PASSed!
Brake shoes, cylinders, rubber hoses, central exhaust pipe and silencer are all brand new now. Had to take the cylinders off with pipes still on it and use heat to tackle the stubborn union nuts.
Many thanks for your help guys.
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
The auto adjust is done by pumping brake pedal. It only needs 2 hand brake clicks to hold my picasso on a small slope. I think yours is normal coz my previous picasso only needed 1 click in most cases.old-un77 wrote:I guess that the auto adjust on the rear brakes, is done by handbrake pull? how many H/brake clicks is the normal? On Mine one click brake is on, two clicks its REALLY on......
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
- My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1 - x 72
- Contact:
Nice when you get a good result like that. Makes it all worth while.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
oops long time not see........Oliver thanks ....I was thinking about limited travel not allowing adjuster advance on the ratchet.....
- Pug_XUD_KeenAmateur
- (Donor 2018)
- My Cars: 405 naD Est
- x 232
glad to see its sorted. Slightly belatedly, I found the exact same problem with brake unions (10mm too small, 11mm too big, including using a Flare Wrench). A 13/16 imperial spanner fits much better.
And.... the brakes look very similar to my 405. Same axle?
Puxa
Yeah that thing is definitely between 10-11mm even when it is new. Weird size.Pug_XUD_KeenAmateur wrote:glad to see its sorted. Slightly belatedly, I found the exact same problem with brake unions (10mm too small, 11mm too big, including using a Flare Wrench). A 13/16 imperial spanner fits much better.
I didn't know 405 used the same axle but just googled pictures, yes it's the same arrangement, trailing arm independent suspension with torsion bar, as used in zx, 306, 205, 206, xsara...
2000 ZX 1.4i
1985 2CV6 Special
1985 2CV6 Special
