Xantia Remote Batteries.
Re: Xantia Remote Batteries.
That's a brilliant guide, I never thought to use a diode from a remote control.
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Adding to the sum of human knowledge...
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
You should add that there needs to be a decent amount of contact between the terminals and the battery. mine has a weird habit of "working", where the light briefly flashes. If everythings ticketyboo the light will illuminate for a second when you hold the button
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
Failing that if you can't get a key fob that works buy a cheap remote kit off flea bay wire it into the locking motor of either one of the front doors and hey presto remote locking will be restored. Probably best to wire it to the passenger side. I am considering this for my old xantia s2 as the new keyfobs available have very hard rubber switch covers that are so. Hard to press it usually results in broken keyfob switches. I have sent the fobs away to be repaired but the quality of the switch soldering leaves a lot to be desired to be perfectly honest.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Thread bump.
Well I have tried the above (mine is a one button key) and it does not work.
Check with a camera....IR LED works, new battery installed
I can lock the car with the button key in the lock, I can lock the car with the non-button key in the door , auto locks work on all doors.
I assume the alarm is not "active" like this ?
So....still struggling to get my single button key to sync
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 825
Does your car have an alarm? They were not standard on French spec cars (and I think were part of the deadlocking option that requires a 2 button plip).Stickyfinger wrote:Thread bump.
Did you try the resync procedure as described on the wiki above?Old-Guy wrote:Alasdair, specially for you, there's a new wiki (Mk1) IR Remote Repair & Re-Sync
If you have another IR key from a different car (even a 2 button one) you could try syncing that.
- Stickyfinger
AX, little Daffodil
- Contact:
Alarm ?....well it has a dome in the roof....actually I have no idea if it does. I just assumed it would have as standard as it has a remote key and a KeyPad
Yes....I followed the Wiki
- chinkostu
Easy way to tell al is to take the battery off with it locked. Car will go ballistic. Otherwise you've got to dig into the nearside arch to see if theres an alarm there!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Stickyfinger
AX, little Daffodil
- Contact:
I will try that as soon as my annoying next door neighbour goes to bed :0
- chinkostu
Or alternatively does it deadlock if you keep the key turned after locking with it? Think dl+alarms were only fitted togetherStickyfinger wrote:I will try that as soon as my annoying next door neighbour goes to bed :0
Edit: Al the vin that the number plate links to seems to say it isn't alarmed.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Old-Guy
I vaguely remember a thread some years back about a possible problem with water getting into the electronic IR receiver unit behind the dome. There are, to my certain knowledge, at least two versions (change-over sometime around 1996-7). As far as I can remember they are electrically interchangeable, but in the earlier design the electronic module clips into the back of the little access hatch, in the later design, the module is glued-and-sealed as (very definitely) integral with the hatch. Perhaps the design change was to fix the reported water ingress problem.
- Stickyfinger
AX, little Daffodil
- Contact:
I have a spare unit, I will have a look......not noticed any water however
