Anti pollution fault
Re: Anti pollution fault
No no oil dripping at all
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1300
- Contact:
well that's good for a start.
Whats the mileage ? and when was the clutch changed (if at all) ?
Do you have a garage you can trust ?
As Richard said, you need to get it checked both for the "fault" and the slipping clutch.....I would encourage you to do this as soon as possible.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
No no oil dripping atall
Yeah I do and about 98000 miles it is on now
'13 3008 1.6 HDi GripControl - x 1003
On the Pollution fault - odds on it's the fuel filter if it hasn't been changed in a while.
On the clutch - these are fitted with an infernal LUK 'self adjusting' clutch and early slippage / failure is common. My thought is that the self adjusting bit just doesn't sometimes. If you can live with it and avoid too much slip by not booting it too much, then so much the better. The kit is expensive, probably needs a new DMF as well, and I fitted one to a C5 and it was a git.
Had my car plugged in and came up with an unknown fault, couple days later the anti pollution fault came up again and so got it plugged in again and came up with fuel rail pressure to low? Anyone know what this could be?
- Gibbo_Wirral
- My Cars: Peugeot 206 Sport 2L HDI
- Contact:
What diagnostic equipment did you use?
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
Solus pro
It's the fuel filter......Dcourt wrote:Had my car plugged in and came up with an unknown fault, couple days later the anti pollution fault came up again and so got it plugged in again and came up with fuel rail pressure to low? Anyone know what this could be?
They easy to change?
Not done one on a 2.0 16V, but shouldn't be too hard - think it's just an element rather than a complete unit (as it is on the 1.6). Take the top off, lift the filter out, fit the new one, top back on, give it a good priming on the hand pump, and away you go.
