Windscreen scuttle trim
DHallworth
Donor 2023
My Cars:
x 125
Re: Windscreen scuttle trim
Post by DHallworth »
CitroJim wrote:I'm pleased I laboured the point now...
You're not the only one!!
That foam that sits on the firewall and runs under the front of the matt looks like a bugger to get out though!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Lexia Available: Yes
My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ)
x 835
Post by xantia_v6 »
David.
Don't go there... stuff a fluffy towel up behind it to soak up some of the water, change the towel a few times. Then wedge something in for a couple of days to let air circulate.
DHallworth
Donor 2023
My Cars:
x 125
It's done...
Well, half done... The Activa is now water tight again. The scuttle has been removed, cleaned and resealed with some black silicon. There's just a little cleaning to do on the bottom of the windscreen tomorrow morning after the sealant on the scuttle has had a chance to cure. Then I'm going to leave that carpet out drying for a week or so.
Annoyingly the scuttle was stuck like sh!t to a blanket all the way along apart from a 3" gap at the passengers side which is where the water must have gotten in. Grand total of the fix has been about 8 quid, it's not an expensive fix, just a time consuming one that's a royal PITA to do!
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Post Reply
