My turn for a C5!
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Re: My turn for a C5!
Hi Marc. Paul had already changed the seats before I got her ( although he did ask if I wanted them; when I said yes he went ahead). The five 30A fuses are in the passenger compartment. I will have to see if MF6 is (unless it works other equipment that was already fitted?).
EDIT; It looks like MF6 will be there, as it does a lot of things, according to this link (fifth post);
viewtopic.php?t=57949
However, Steve posted (last post in this thread) that he added fuses MF4 & MF5, but I don't know if they would be for the whole seat, or just the heated function.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
MF6 is an 80Amp Fuse and provides the supply to the whole of Fusebox BH12 that contains up to 5 fuses:
F36 - Trailer Unit
F37 - Pass. Elec Seat Adj. Relay
F38 - Drive Elec Seat Adj. Relay & 12 V Forward Socket
F39 - Radio Amp (HiFI Equaliser Amp Option only)
F40 - Pass / Driver Heated Seat Timer and Relays
F36 - Trailer Unit
- Donor 2023
- x 3007
Hi all,
I need to pick brains (as I would not pick my own, given a choice!). My C5 has decided to throw her toys out of the pram. I was accelerating away from a roundabout (and she was in Sport mode) when there was a drop in performance (she is reluctant to idle and is 'lumpy'). I had her recovered, and my Lexia shows P0299 (in the Injection menu, and NO other faults are shown there). I think an intercooler pipe somewhere has failed (which would make sense as it happened under acceleration). I assume that the air flow goes from turbocharger to intercooler to intake manifold. Would it be possible for anybody to confirm this?
Thanks.
Thanks.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- x 3007
OK, well I have found something. The 'rubber' pipe that connects to the intercooler (from the metal pipe that seems to be connected to the turbo, passing under the engine/gearbox) is looking unwell. It is loose where it joins onto that pipe, and there are clear signs that soot has blown out of this junction. Could somebody let me know about BOTH of the pipes for the intercooler (I am of the opinion that if one has failed the other might be following it.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Dormouse
- My Cars: Peugeot 3008 Hybrid4, Fiat Ducato, Morris Mini.
plus notable cars I have owned :- Studebaker 1921, Daimler Consorts, Mercedes 220 Pontoon, Simca 1301, Austin Metropolitan, lots and lots of Minis, both steel and fibreglass bodied, Fiat 500F, Citroen GSA's, Skoda Estelle 120 Rally replica, DKW 1000S, Triumph Herald Estate, Warwick GT (very briefly) - x 666
generically P0299 is low turbo output so a hose that has popped off would put you into limp mode
- Dormouse
doesn't this layout have 3 rubber hoses - 2 for the intercooler ends and one to the inlet?
- Donor 2023
- x 3007
The rubber pipe in question has a spring clip to hold it in place, but if there was a jubilee clip (to seal the rubber pipe to the metal pipe) it has long gone. I may have one large enough. However, when she is 'lumpy' she feels like something unbalanced is spinning. Would that be due to the bad air flow?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Dormouse
can you get someone to work the throttle while you check if the pipe is blowing? not the same as driving I know. Silly question! Is the pipe that is "blowing" definitely the feed from the turbo?
- Donor 2023
- x 3007
Looks like I need a jubilee clip 220mm in circumference.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Dormouse
by my calculations that is 2 3/4 inches - 70 mm. A hose with a spring clip on should resist blowing off though
- Donor 2023
- x 3007
The metal pipe (where it joins with the rubber pipe) has been widened to allow the spring clip to retain the rubber pipe onto the metal one. The jubilee clip is there to make the seal by tightening the rubber pipe to the metal one. The rubber pipe clearly has the indentation of a jubilee clip about 1cm from the spring clip. Because this pipe is so low down (it passes under the gearbox/engine) I think it has picked up crud (there is currently no undertray) and slowly corroded through. I was booting her away from a roundabout (Sport mode in a 2.2L twin turbo C5 is FUN!) when she complained, so probably the jubilee clip gave up, and then the pressure was able to escape through the junction. I will get a couple of jubilee clips from B&Q (about £3 for a pair), fit one, slather it in grease (not sure which is better to protect it), and see what happens.
Michel told me that, when he had intercooler pipes fail on a Skoda and a Xantia the cars became gutless and lumpy (like they were running on a couple of cylinders), so I hope the clip will get her back to her spirited self (and we can enjoy startling sports cars from the lights!).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- x 3007
OK, well, that jubilee clip did NOT resolve the problem. The jubilee clip is done up nice and tight, but she is still gutless and lumpy. Drat.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
- x 3007
Well, I suppose I had better update this thread.
It appears that the cylinder head has taken damage. I took her to a specialist, and he did find a couple of timing issues. Once these were resolved he turned the engine over manually, and it appears there is poor compression on two cylinders. She will run, but not well.
I have three options here. I can try to get her fixed, sell her as spares/repairs, or scrap her. Given the choice, I want to get her fixed. I KNOW that I will have to spend more than she is worth (on ebay there is a similar C5 (but Exclusive as opposed to VTX+) gong for around £2,400), but I am looking at the long game. There are Xantiae going around that are 30 years old. My C5 is 14 years old, and she could last for another 14 years if she is looked after. She has a nice amount of toys (both from when she rolled out of the factory, and from being added later in her life), is comfortable and (when she was working properly) is quick and economical, and has plenty of space.
I do not have the resources to sort her out myself. I neither have the knowledge or the space to fix her myself. The mechanic where she is currently is has declined to work on the head (he does not take on the 'heavy' stuff), I have lost faith in another Citroen specialist I used to use (I am not going to explain why), but I have a couple of feelers out. There are a couple of other things that need looking at, but until the engine is running properly there is no point in fixing these. I know there was an offer (on a thread started by Michel) of a cylinder head from MGmike. I will have to get into contact (and discuss the logistics). Michel had suggested parking the C5 on his driveway for us to work on, but for personal reasons (that I entirely understand) he has had to cancel that offer (although, through him, I have the use of a Xsara Picasso, so I am still mobile. Thanks, Michel).
viewtopic.php?p=688350
All being well, I hope I will be able to say she is running properly and providing me with good service at some time in the future.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
I refuse to agree head damage. Untill the rocker is removed I'd hedge my bets on rocker fingers being the culprit for the lack of compression. They are designed to break rocker fingers rather then valves or head damage..
Id strongly reccomend looking at rocker fingers..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- x 3007
I will get the rocker arms checked first.
Is there a guide anywhere on the Forum to explain how to do so? I know that the 2.2l engine is not covered by Haynes, and the Pocket Mechanic guides (that do cover that engine) do not have good reviews.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
