cheers Bobins, I will hold off ordering one until you have finished your Time Team dig
vborovic, cheers, I am not totally sure of what to search for with these interface leads, any help would be great, thanks. (I only really use the volume controls)
edit
Anything here ? ..... http://www.connects2.co.uk/VehicleProdu ... odel_ID=51
C5x7, fan not on, Removing the bumper for access
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Re: C5x7, fan not on, overheat warning
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- SaabC5
- My Cars: 09 C5 X7 2.0Hdi Exclusive
Not so, there's this one available on eBay. I know it works because i've got one installed in my X7 with my Alpine head unit. You will also need a radio adaptor cable for approx £4 and the appropriate patch lead. Be prepared for lots of swearing however, there's sod all room behind the head unit and the silver box is quite a large unit, it needs to be pushed down below the radio behind the storage cubby hole. You will lose your parking sensor beeps if its not can-bus compliant.
http://www.ebay.co.uk/itm/CITROEN-C5-C8 ... 5657117432
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
- Locked user account
- My Cars: A used Citroen
- x 27
Well, that's not actually a patch cable, but the entire mid-unit ... so, of course it works (but, I didn't know about it, true, never searched in detail since I don't have a need for it) ... if you have extra room (and long cables to reach everything), you could try placing that silver box behind the multifunction screen, or nearby it, there should be plenty of room available
Those box ones are the only type I've ever seen work with can network cars. They are a pain though, I refuse to fit them for people as half the time they just don't work.
- Stickyfinger
AX, little Daffodil
- Contact:
Thanks for finding/letting me know about that......worth considering.......time for an ebay search.
So what is the phono plug for ? and does it worth with a Bluetooth head unit (eg external mic)
- Stickyfinger
AX, little Daffodil
- Contact:
OK chaps....time to sort the cooling fan this weekend....so...HELP
Has anyone taken off the bumper ?, I have so far got :
removed wheel arch screws (x2) each side, and pulled back the liner (cannot see any more in there ? is there a clip ?
6x screws on the under tray
all the plugs on the top tray/cover,and the covers over the lights
Central intake grill screw and the side light trim screws, and the side light units with their screw.
.........Does not seem to want to move
edit:...Does anybody know where the fuse for the engine fan is located ?
- Stickyfinger
AX, little Daffodil
- Contact:
OK....so I started trying to work it all out concentrating on no distorting plastic of ripping out lips or lugs......this is what I found.
2 bolts per side, view the white "turn buckles" in the leading edge fold
Release the bumper D clips with a plastic tool, push it in under the bumper and work along one at a time
(View from Outside to help show clearly...this happens inside the wing ! )
Using the tool I twisted the turn buckles, I used rod both reach and so I could use a spanner (tough to turn by hand)
edit
This is way to complicated.....bend some rod and thin the end.....I was experimenting as I went and the welder was plugged in
Then pull the bumper forward wriggling as you go
edit
- Stickyfinger
AX, little Daffodil
- Contact:
Re: C5x7, fan not on, Removing the bumper for access
Rad cooling fan has gone I think....the relay "clicks" with 12volts supplied to it so the £16 part is OK but the fan does not work....so it is stuffed I think.
These fans are "two-speed" so cheep replacement ones do not work and you are limited to an OEM one (I Think? )....does anyone know a good well priced source ?
Citroen about £500....Ebay £350
- Stickyfinger
AX, little Daffodil
- Contact:
New fan ordered, £225 from Poland, £12 shipping ..2 days....Original PSA part 1253T3 (updated) fan unit
- Stickyfinger
AX, little Daffodil
- Contact:
Job done,
I "raced" myself and to a grand total of 14.25 mins to get the bumper back on and all lights working/in-place and the bonnet down.....why was I worried by the bumper off/on ? , an easy job and I urge you to DIY if/when needed.
