Lexia installation woes....
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1290
- Contact:
Re: Lexia installation woes....
LOL, you know you lost him at Stage 2 don't you
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- The Ace
- My Cars: Citroen C5 1.6THP Prestige
Ford Fiesta 1.0Ecoboost Titanium - x 1
Now that I re-read my post, yeah probablyStickyfinger wrote:LOL, you know you lost him at Stage 2 don't you
However, someone on the same time-zone and availability could Teamviewer-in on his PC and do all these remotely, they are indeed pretty straight-forward for someone with some basic IT skills....you can fiddle with the VM settings, or the WinXP VM environment parameters, but these are tune-up steps and not required for the basic installation.
I just wanted to provide a step-by-step, just to try to give the OP an idea of the required effort....
- Stickyfinger
AX, little Daffodil
- Contact:
You did mate,
Hi
I am having a bit of a problem with my diagbox install as well. I am running on Windows 7 Ultimate 64bit. I have successfully installed the diagbox/Lexia/PP200 software and (I think) all drivers included on the cd it came with. My problem is that I am getting a "Please connect a VCI" after choosing my vehicle model (Peugeot 206). When I plug the interface into one of the USB ports the light flashes normally (3 flashes etc) but I get no sound nor does anything appear in my device manger, it is as if the computer is not recognizing the box... Is this because of windows 7 64bit or might it be something else ?
Big thanks in advance for any replys !!!
2005 Peugeot 206 1.4L hdi
- Stickyfinger
AX, little Daffodil
- Contact:
when asked, try switching USB ports. I also boot the PC with the unit in the usb port.
Tried all of that and no luck, Is it possible the unit might be faulty ?
- Stickyfinger
AX, little Daffodil
- Contact:
More like its clashing with 64bit Windows....my Windows7 disks came with both 32 and 64 bit disks....I installed 32bit on the LapTop and 64bit on the main box.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
As Lexia is very old software (16 bit) it cannot run directly within a 64 bit environment. You will need to set up a virtual machine (I cannot advise on how to do this), and then set up a 32bit O/S in the VM, and then install the Lexia software there.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- The Ace
Most likely...whenever I tried installing on 64bit (7 or 8), the installation failed and/or the app didn't actually work. I then decided to go straight to WinXP, and voila, everything worked flawlesly from the word "go"RM206 wrote:I am having a bit of a problem with my diagbox install as well. I am running on Windows 7 Ultimate 64bit....Is this because of windows 7 64bit
Ok great. All the installations are fine, diagbox, Lexia, PP2000. It all starts up etc perfectly, it looks like the drivers don't like windows 7, the Diagbox cable isn't appearing on the computer.
Will have a bit of a fiddle and then try a virtualbox with xp.
Thanks !!!
Thanks !!!
How about windows 7 32bit ! I have an old computer running that. I will try that first and report back.
That should be OK. Not tried it but planning to soon and my research says win 7 32bit is good for Lexia. Probably.
- Donor 2023
- x 3007
I am using Windows 7 Starter (32 bit), and my Lexia works with it
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Still no luck... installed on 32bit windows and same error "Please connect a VCI"... Might be a faulty box :'( Very frustrating anyhow... It is defiantly the drivers I have. they will not install correctly. If anyone has the working "ACTIAPnP" drivers I would be very grateful
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
These any good? http://www.driverscape.com/download/usb ... stance-%29" onclick="window.open(this.href);return false;
