Xantia failed smoke test
Re: Xantia failed smoke test
My car failed the ITV a couple of years ago. 2 things, waiting for the test the engine had got cold, and didn't thrash her on the way there. The inspector told me to drive round the block fast, which I did and then she passed. I rev her hard on the way each time now, never a problem.
You only get the first retest free though.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
I was a bit concerned about emissions at the last mot so I drove there in 2nd gear. The car got a "fast pass" and the tester said he was surprised as normally he has to rev the life out of an old diesel after it fails to get it to just pass.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1298
- Contact:
Rule of Thumb for an MOT....
No 1............. NEVER test a cold car, all test figures are based on engines/cats at full operating temp.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
If I run a mix of vegetable oil with petrol for a while, will this help clear the injectors??
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
I don't think it would. Some injector cleaner will, don't put it in before an mot or equivalent though as it creates exhaust smoke while it does its stuff.
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
Run some injector cleaner through via the fuel filter? Drain a bit out and top off with cleaner? Will run like crap for a few minutes like!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
I've noticed there are two adjusters on the Bosch VE fuel pump-
- Full-load screw adjusting screw
- Smoke adjustment on top of the diaphram
Which of these should I play with to reduce the full throttle smoke??
- chinkostu
The screw on the top of the pump adjusts the height of the LDA pin before boost. Futher down - more fuel. The one on the side of the pump adjusts fuelling across the whole range. Might be worth winding the top one out all the way
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
The "smoke screw" on top, is for off-boost fuelling, which will affect smoke as you pull away from standstill (low-ish rpms). The MOT test (at least in the UK) concentrates more on full power smoke which is related more to the other adjustment you mention.
- chinkostu
You can also take the top off and rotate the LDA to a more agressive profile for more fuel. Need to adjust boost afterwards thoughMikeT wrote:The "smoke screw" on top, is for off-boost fuelling, which will affect smoke as you pull away from standstill (low-ish rpms). The MOT test (at least in the UK) concentrates more on full power smoke which is related more to the other adjustment you mention.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
True, except the aim of this post is to reduce fuelling/smokechinkostu wrote:You can also take the top off and rotate the LDA to a more agressive profile for more fuel. Need to adjust boost afterwards thoughMikeT wrote:The "smoke screw" on top, is for off-boost fuelling, which will affect smoke as you pull away from standstill (low-ish rpms). The MOT test (at least in the UK) concentrates more on full power smoke which is related more to the other adjustment you mention.
- chinkostu
TrueMikeT wrote:True, except the aim of this post is to reduce fuelling/smokechinkostu wrote:You can also take the top off and rotate the LDA to a more agressive profile for more fuel. Need to adjust boost afterwards thoughMikeT wrote:The "smoke screw" on top, is for off-boost fuelling, which will affect smoke as you pull away from standstill (low-ish rpms). The MOT test (at least in the UK) concentrates more on full power smoke which is related more to the other adjustment you mention.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- Stickyfinger
AX, little Daffodil
- Contact:
it may be a "Need" but should never be an "Aim"
Loosen the lockout on the screw on the back of the pump (RH side as you look in at it). Screw out the screw about 1/4 turn (anticlockwise). It will leave you down on power throughout the rev range but will greatly reduce smoke. After the test reverse the process. On the other hand as I suggested before throw a bottle of dipetane in the tank the day before the test. Give it a good hard run. I have never seen a smoke reading above 1.5 with dipetane in the tank.
I am sure that there are other brands that will do the same. I think STP also sell what they call an NCT pack here. It will reduce emissions at least well enough to get you through the smoke test.
- chinkostu
Stickyfinger wrote:it may be a "Need" but should never be an "Aim"
Mine hazes like mad on full boost, need to wind the wastegate up! But it picks up so much better
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
