Defeat on every turn
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Re: Defeat on every turn
Was using a good spanner, so tight the shoulder has just split/bent destroying the seal channel....its totally fecked. Still good for a JimBoy repair so I will keep it on one side if he ever feels the need to do that again
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- darbuck
- Donor 2023
- My Cars: 2008 Citroen C5 X7 Tourer VTR+ (138 BHP)
2007 Nissan Primera P12 1.6 T-Spec (110BHP)
2003 Citroen C5 Estate level 2 (110 BHP) 2.0 HDI
2001 Nissan Maxima QX 2.0 V6 - x 135
hi sticky ,
been a while since ive been on as to your predicament im probably suggesting something you have already tried but heat is the only thing that will seperate threadlock as its an elastomer and designed to resist oil based solvents i would suggest using an impact type socket as they're much stronger than standard and are 6 point for better grip. hope it helps buddy.
Darren
- Stickyfinger
AX, little Daffodil
- Contact:
Cannot get anything other than a spanner on it mate......its the alloy that just gives way....not designed to move....ohh... and I "cooked" it for an hour in a Rayburn, the thing has fallen apart at the edges/seal channel
FYI, C is a very soft aluminium
- darbuck
- Donor 2023
hi sticky,can you concentrate the heat on the long part of C as it might just expand enough to release the thread on H it could be a combination of thread lock and electrolysis causing it to seize ,aluminium expands slightly faster than steel alloy so should in theory if heat is concentrated expand enough to loosen try spraying gt7 or plus gas on thread and then ignite after 2 or 3 min and keep heat on it it worked for me on a thread locked engine mount i know its a bit iffy but if it works.
he who dares wins and all that
Darren
- Stickyfinger
AX, little Daffodil
- Contact:
H out of C, but I have to grip/hold C to prevent it turning
- darbuck
- Donor 2023
Im presuming its off the car so your obviously using a vice if im correct in both these assumptions h is stronger than c but c allows for greater leverage as it has a greater surface area so i would be locking h in the vice and applying a deep socket on c as h is stronger than c it can be held with greater force than c i really think your main problem is spanners rather than sockets as you wont get the same pressure and leverage on the work piece.
Darren
- Stickyfinger
AX, little Daffodil
- Contact:
I am using a vice as well, tried both ways. In the vice, it just turned and ripped up, then it crushed. The glue holding it is stronger than the metal can cope with.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
OK, that would suggest it rhymes with duct! If you have another one to do in the future I would suggest a few temperature cycles if the metals will take it (good and hot, nice and cold using freezer spray, repeat) to see if that worries the thread-lock.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- My Cars: 2006 C5 2.0 Litre HDI VTR Automatic Estate.(now sold on)
Currently Renault Zoe 2014 ZE - x 2500
Try to reinforce C along the full length of where the threaded portion of H screws in, Evostick a few layers of paper, (or leather) round it to give it extra strength before you attempt to unscrew it. Don't use the hex head on C, clamp the reinforced bit in mole grips or a vice.
Man is, by nature, a lazy beast, he does not need twice encouraging to do nothing.
