Removing condenser from C5 X7 and disable automatic lock
- osx
- Lexia Available: Yes
- My Cars: GSA X
BX 1.6
C5 X7 Auto
C5 X7x2 Manual - x 15
Re: Removing condenser from C5 X7 and disable automatic lock
They can't see any leak after regasing and retesting so they think it could be a leak behind the dashboard. Don't think I am going to bother tbh if it is just a matter of topping up a couple of times during the summer unless there is another solution.
C5 X7 Exclusive 2.0 HDi Auto
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1296
- Contact:
IF the leak is still there....and is now behind the dash "they think"....who told you to change/renew the condenser rad ? was it a guess or was it the re-gas/air-con firm ?
does the condenser really leak then ?
for what it is worth, I would not be happy with Air-Con gas leaking into my cabin
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- osx
- My Cars: GSA X
BX 1.6
C5 X7 Auto
Will find out in the following days - I am sure there is a leak somewhere and was surprised when they told me that they couldn't find anything. Didn't ask what tests they did though. They suggested getting a car aircon specialist to have a look but getting fed up paying £££ just for diagnostics and no fix.
- DickieG
- Monaco's youngest playboy
- x 38
If you fancy a run up the M4 I'll look at it with my UV light and sniffer, if it's had dye put in it it'll show up somewhere, if the leak is from the evaporator then the sniffer will detect gas leak out through the vents.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
- osx
- My Cars: GSA X
BX 1.6
C5 X7 Auto
Thanks Dickie. Will see how things are with work. Is it something that needs to be done while there is still some gas in the system?
- osx
- My Cars: GSA X
BX 1.6
C5 X7 Auto
Strangely enough the aircon has been working fine for over a month. Don't think the air is as cold as it should be at Low, but keeping the temp at 20 C has been fine. Not sure why it is working now after a month when it just failed after a few days with the first regas. I do keep it on all the time now.
- osx
- My Cars: GSA X
BX 1.6
C5 X7 Auto
Had a go and there is certainly enough room to remove the condenser but can't remove the lower connector. Seems that you have to remove the bumper to get proper access to this last nut from the front of the car?
- My Cars: BMW 635D
Citroen C5 Tourer (X7) 3.0HDi Exclusive
407 Coupe 2.7vh HDI
206 gti180
206 GranTurisme (Sold)
BX Gti16V (Phase2) - x 244
Holy necro batman! An 8 year old thread resuscitation.... Incidentally coud I get a copy of that searchable PDF manual mentioned earlier?
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5741
I wouldn't touch that site - it's full of malware Jay. Are you referring to removing the condensor?
