I'm sending bac the flare nut set for a refund ("points" were roundish and "flats" uneven) and will be trying a six-pointer 11mm instead. Otherwise I'll hand it over to a garage to be done - probably Dory's as they can make up a new pipe should the old one get destroyed during removal.
And after the pad parts fiasco, I'm having same difficulty getting the right caliper service kit - the seller first asks for model, year etc but then replied that wasn't adequate, please supply reg. After sending reg they then tell me that's not good enough either - is it Bosch or Bendix. They tell me it will be stamped on the caliper but unfortunately there's a sodding great wheel in the way (yes, just taking a wheel off isn't such a simple task for me anymore, let alone spotting a makers name).
I know the pad spring kit said it was suitable for Bendix brakes but that's about all I know. Is there any other method of determing which I have? I'm inclined to order bendix and swallow the returns costs if it turns out I have Bosch brakes. If it helps, I do not have ABS or pad wear indicator circuitry.
Which Xantia front brake pads
Re: Which Xantia front brake pads
your front brakes are Bosch Mike
here is a screen shot from service citroen on your chassis/VIN No.
https://www.dropbox.com/s/k7fvz02c96lyh ... 1.png?dl=0" onclick="window.open(this.href);return false;
Regards, malcolm.
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 231
So simple when you know how - why couldn't parts supplier figure it out lol. Cheers Malcolm!
Told seller I have Bosch, they send item number of part which according to their reference database is listed for Estates only. I give up for now.
