Sounds like an easy fix... Both if its just corosion or the tranmitter board.. I have a PP2000 so that is not a problem... Thanks...Hi Peter, if its flattening those batteries it sounds like you need a new key. I would study it well to make sure no corrosion anywhere and to check if the circuit board is in good shape, a new one can be coded for your car by someone who has PP2000 near you or possibly a good key shop. If you get a new one make sure so move the small black chip over too, that's critical for making the car start!
Central lock Peugeot 406 2.0 HDI year 2001
Re: Central lock Peugeot 406 2.0 HDI year 2001
Also a possibility... thankscitronut wrote:maybe the micro switch's on your plip circuit board are sticking so causing the battery to run flat
