back onqprdude wrote:Does the car drop into economy mode soon after switching the engine off, even after relatively long journeys?
C5 Exclusive, Central console keeps restarting itself and...
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Re: C5 Exclusive, Central console keeps restarting itself an
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- qprdude
- My Cars: Renault 5 TS, Renault 14ts, Citroen C5 Mk1, Renault Clio sport, Renault Laguna Privilege. Citroen C5 X7 Exclusive. Citroen DS5 D/sport . And around 25+ other brands from Morris Oxford to S Type jag and most things between.
- x 10
My book says "a maximum of 30 minutes"
Rick.
2013 Citroen DS 5 D/Sport
- (Donor 2018)
- Lexia Available: Yes
- My Cars: 2008 C6 2.7 Exclusive in Mativoire Beige with Vitali Leather.
2017 1.6HDi Berlingo Van - the works van - x 42
- Contact:
Might be a good idea to get a Lexia/Diagbox hooked up to it. at least that way you can run a couple of tests........ personally I think the disc being stuck in the head unit is the problem.....
Steve
http://c6owners.org/index.php
- Stickyfinger
AX, little Daffodil
- Contact:
Disconnect the radio for a bit and see what happens ?
Yes it does go into economy mode very soon after switch off, i'd say about 5-7 mins. also as soon as i unlock the car in the morning 'ecomony mode active' displays in the dashboard even before i open the driver door.qprdude wrote:Does the car drop into economy mode soon after switching the engine off, even after relatively long journeys?
And as for the radio/cd unit it seems to be working ok now since yesterday, it did not have any cd inside it as i use the hard disk for music. so still dont know what caused it.
As for the poor battery, i had a full service done last year at 55k shouldn't they check the batteries at that time?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
Batteries fail over time. What might have been good 6 months ago may no longer have sufficient capacity for the job. Simply put, the battery has got old and tired!
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
I'm not sure that a full service would normally include what is known as a "load test". The battery check would be more like "Yep, it's still there".
This is the only way to establish the actual health of a battery, and a reputable battery shop will likely have no problem telling you if it's not ready for replacement. It's madness to play guessing games when the state of such a pivotal item is unknown.
Thanks for your response guys. I'm still getting the car on limp mode with all codes flashing when i stop the car and start it again within an hour or two. Its ok if i start it after two or three hours. Yesterday it conked out twice, once in the middle of a junction and once when i started it.
I struck between the faulty fusebox and bad battery. Although the check button does not give any fault readings.
But as you guys have pointed out, i guess the battery needs changed anyways. But can a bad battery make the car cut out in the middle of a run?
- Locked user account
- My Cars: A used Citroen
- x 27
Once again, the CHECK button won't give you any useful feedback, it will show the service interval, maybe the ECO parameters and deflated tires (the messages that would usually only appear on the instrument panel matrix display, nothing more that that ...)
hey guys, alas the car gave up the ghost over the weekend , it would start and within few meteres of rolling all errors mssgs popped up along with limp mode. left the car untouched for three days and this morning started ok and took it to garage without any mssgs flashing.
Now the garage has run diagnostics and they say its a CAM sensor failure and quoting 103 quid for new part with fitting and another 60 for diagnostics.
Should i go with what they say?
thanks.
thanks.
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
Xantippa wrote:Fusebox..?
- Stickyfinger
AX, little Daffodil
- Contact:
If they do not have a Lexia....then they are more than likely guessing.................up to youFedupofc5 wrote:hey guys, alas the car gave up the ghost over the weekend , it would start and within few meteres of rolling all errors mssgs popped up along with limp mode. left the car untouched for three days and this morning started ok and took it to garage without any mssgs flashing.
thanks.
What unit did they use to code read ? cus if not a lexia////
edit:
As Addo said below
