I am an Activaist-v6
Contains the Activa Register, Buyers Guide and Activa "finds" on eBay and elseware. Post Activa-specific items there that do not fall naturally into the Citroen Forum.
x 1055
Re: I am an Activaist-v6 and suffer AX-isum with a touch of CX TurboGTI'itus
Post by CitroJim »
CX-cellent :)
Donor 2016
x 716
Post by Stickyfinger »
Keeping at it whilst the sun shines and stuff in the engine bay dries quickly.
Slam-panel rubbed and painted (zinc and first silver top coat to protect)
Spare wheel plate refitted, wheel cleaned and painted, tools and brace also.
Various pipes cleaned, rust-eater, painted or waxed, many pipes needed spacers replaced to prevent rubbing/chaffing
and other stuff.
Donor 2016
x 716
Well it is that time again
One washed and off to bed
and another awoken from its summer slumber (7-8 months) but started on the button. (well screwdriver as I had to drill the lock out having lost my keys !)
x 1055
Post by CitroJim »
Excellent! Just as I find with my Saxo... It can stand for months and then start instantly... Even without a battery top-up...
These little Cits really are rather excellent little cars...
Nite, nite Activa - sleep well and watch the tinworms don't bite!
x 1791
Post by GiveMeABreak »
Looking fantastic Alasdair.
Fake Concern
x 41
Post by Fake Concern »
I don't even know which of your cars I like the most now!
Now you need a C4 VTS 180!
Donor 2016
x 716
Nor do I, but I use Man-Logic to reason why I have 4 runners.
I will guess at:
ACTIVA
AX
C5x7
CX
Still want an H-Van on a Land-Rover chassis :)
x 1055
Post by CitroJim »
Stickyfinger wrote:
03 Nov 2018, 08:53
Almost as desirable as an H Van with an ES9 V6 engine and Activa suspension :wink: :-D
Donor 2016
x 716
Jim, that would just be a bad Activa :)
x 1055
Post by CitroJim »
Stickyfinger wrote:
03 Nov 2018, 12:52
OK, Good point well made! delete the Activa bits but leave it suspended on green balls ;)
Donor 2016
x 716
But then no 4x4 drive and it would neither Citroen or LandRover owners :)
x 1055
Post by CitroJim »
I believe there's been a Land Rover or two converted to Citroen suspension Alasdair... Do I understand that in doing so renders them 2WD only?
donor 2020
x 671
Post by bobins »
If you're after a bit of inspiration as to what can be achieved with grafting one vehicle into another, then I can thoroughly recommend 'Project Binky'. A mildly challenging concoction of putting a 4WD Toyota Celica 2.0 litre engine, gearbox and drivetrain into an old Mini. The videos are stupidly funny, but it does actually show you what can be achieved if you really don't want to be defeated by anything. They have an engineering solution for absolutely everything :lol: They've been at it for 4 years now and have only just got to the stage of putting in the wiring harness ! Thoroughly recommended viewing... if you've got a day or so spare to watch all the episodes :)
x 1055
Post by CitroJim »
bobins wrote:
03 Nov 2018, 20:48
That is wonderfully bonkers!!!! Love it 8-)
Donor 2016
x 716
High flow return 5-way leaking.....oil on drive....gerrrrrrrrrr
Looking in through the left side wheel arch.
Leak at 2 on the "ribbed Moulded pipe"
Pipe cut and a small section inserted...and leaking at 1
