i assume you know that the aircon heater system is the same in both C5 and 407.....
......as is the engine, gearbox etc etc
c5
- VertVega
- x 13
Re: c5
In mine (MK2) the right side has been blowing ONLY Cold for about a month nowStickyfinger wrote:More of a problem with the Mk1's I think....still needs check however I agree.VertVega wrote: One more thing to check: make sure that the dual zone air conditioning
is working on both sides (left and right).
Broken heater flap is common and repair is not cheap The broken side blows cold air.
The good part of it is that, right side is the passenger's side here
That's true. It is an issue with both MK1 and MK2. Also don't skip the 407's.hamster99 wrote:The broken heater flaps on the dual zone aircon is an issue with mk1 and mk2 (facelift) versions.
I'm planning to fix it on my own. Just need some time and warm weather
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1300
- Contact:
Re: c5
Gents, that is how you do not become a Citroen owner
Activa, the Moose Rider
3x C5x7 Steering racks and counting
