mrtee wrote:Im happy to have a go at bleeding the system, can anyone recommend a step by step guide to this?
firstly locate all/any bleed screw/vavles,
on XUD's ( cant remember if this is similar on the HDI's ) i remove the bung/plug at one end/top corner of the rad, then fill the header tank till coolant comes out of the top of the rad and stops sinking,
then replace the rad bung/plug and open any other bleed screw/cap and keep filling the header tank till coolant comes out of these,
if it doesn't at the point start the engine and bring the revs up till you get coolant coming from the bleed screws/caps,
refit each bleed screw/cap as you get a good flow of coolant coming out of them,
once all the bleed screws/caps are refitted continue to run the engine ( checking coolant level all the time ) till the level seem steady, now refit the header tank cap and continue running the engine till the fan/s cut in and back out, then gently open the tank cap, they sometimes erupt the first go round, so just go through as much or little as you need again to the point the fan/s cut in and back out, then check how calm the coolant is
