st st stuttering 2004 c5 hdi
Re: st st stuttering 2004 c5 hdi
did you get rid of the stuttering , i have a potentially similar problem, with it happening at random times, on odd occasion engine completely dies and wont start for a few mins. have read codes with lexia and nothing conclusive.
Nothing so far this morning but it's probably a bit early to be certain that the fuel filter solved the problem.
15 C4 1.6 eHDI 115 Exclusive - better half's
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
it would take a lot of gunk to clog a filter that bad i would think so not sure either about that
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
\It does not have to, just drop the rail pressure and the ecu will cut the car.....?haydent wrote:it would take a lot of gunk to clog a filter that bad i would think so not sure either about that
Activa, the Moose Rider
3x C5x7 Steering racks and counting
good to know, but still i imagine it would take a fair amount of junk to reduce the fuel filter flow rate that much considering their surface area, but i guess if it where dispersed through the fuel it could build up homogeneously.
- Stickyfinger
AX, little Daffodil
- Contact:
You would think.....but the C5 and many common rails are very sensitive to fuel flow/pressure.......haydent wrote:good to know, but still i imagine it would take a fair amount of junk to reduce the fuel filter flow rate that much considering their surface area, but i guess if it where dispersed through the fuel it could build up homogeneously.
You need to get it on a Lexia to really find out the problem.....
i did and there are no consistent errors with the symptoms
- Stickyfinger
AX, little Daffodil
- Contact:
and that points back to a filter.....haydent wrote:i did and there are no consistent errors with the symptoms
FYI, failed/ing MaF sensors as an example, give strange "driving faults" as well, power loss etc, these are often not recorded in the software either as the car thinks it is doing what it thinks it should with the readings it is getting. This is where the group experience of the people here can save so much time chasing snowballs in the summer. Hope its cured and the consensus is correct.
thanks, yeah map sensor is currently at the top of my suspect list http://www.frenchcarforum.co.uk/forum/v ... =3&t=50692" onclick="window.open(this.href);return false;
- My Cars: 2004 c5 2.0 hdi 138. *gone*
1988 pontiac firebird.
1996 1.8 8v xantia auto. soon to go .......
1999 2.0hdi xantia estate - x 16
Completly didnt have time to come back to this earlier, my mechanic came and hooked up his computer, imediatly said everythings fine, fit a new fuel filter. Well when I took the old one out I could not believe how bad it looked after just 10k !! New one fitted, runs like a dream now. I plan on swapping the fuel filter in sixmonths just to be sure and not damage the engine in any other way. Also shortly after, I had the cambelt replaced and it starts instantly, feels smooth and dosnt run on in shutdown, that must have been in bad shape too ! Hopefully its good for another 80k !
good to hear that. i replace my fuel filter every 10,000k which is only a couple of months with the k's we do, so it never gets that dirty
well mine is still doing it, mainly stalling
