Hi, its on the topic so NP
The big plug is down behind/below the back of the engine/below Air-Filter box (remove) and is a bit of a pig to get at from above, but given 3 fingers and a 6 foot arm you should be fine. I just sprayed it good with contact cleaner and reconnected.
The seat wires that were chaffed were inside the plastic protector itself that is attached to the underside of the seats, the insides of the plastic were razor sharp on mine !....I still wonder how this could effect the cutting out....
scary experience
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Re: scary experience
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- My Cars: 2004 c5 2.0 hdi 138. *gone*
1988 pontiac firebird.
1996 1.8 8v xantia auto. soon to go .......
1999 2.0hdi xantia estate - x 16
It does not suprise me at all, when playing suspension games I had a different suspension computer plugged in and it registered a brake airbag and seatbelt fault. And would not let me start the car ! Plugged the old one back in and all was fine.
