http://www.salonsdirect.com/products/ha ... wwod8w8ADg" onclick="window.open(this.href);return false;
new project brought
- Donor 2016
- x 735
Re: new project brought
All/ANY required essentials for a MG Owner (any)
- x 42
Sorry I missed this, the head is toast, the engine has been overheated and anealed the head, its gone soft and the compression seals have pushed into it, it will just happen again and cause hgf, sorry should of read your posts through, be very carefully the block hasn't softened and the liners have dropped also. This is why you must retro fit a coolant level sensor, its lack of coolant that kills the hg and if repeatedly over heated the rest of the engine, I personally would junk the engine and get a good second hand unit, fit a be head gasket and make sure there areno signs of overheating while your at it.jgra1 wrote:silver and yes Elma
but.. really struggling to get an measurements of the cylinder liners.. will try again tomorrow..
also there are some minor rings in the head..
still looking like it may not go again reliably.. only30K miles too !
Again sorry didn't reply sooner and its not good news
D
- Donor 2016
- x 735
On the K engine, I thought this was great...may keep you calm
- x 42
I remember well stripping and cleaning e v e r y. S i n g l e. B l o o d y. F o l l o w e r. Which of course must be done to get the Mayo and crud out, its an easy hg change to do if it hasn't been owned by an idiot before hand.
Its not a relaxing watch by the way
D'
D'
That's the speed some people would like their car worked on,Stickyfinger wrote:On the K engine, I thought this was great...may keep you calm
- x 19
thanks Dean / all
head went today to the engineer.. I think it will be ok.. his most common skim, the K series, I asked him how bad the fire ring depression gets.. 1mm ! was the worst he's seen.. (junked)
Mine is more like 0.05 .. its going to be ok ..
- I see no signs of overheat, all I see is a failed original gasket..
I am going for it..
car has only gone 30K, head dismantled and mostly through the parts washer..
watch this space
John
I am going for it..
watch this space
John
- x 19
hehe like the video,
song sounds nice, whatever she is saying
- x 42
Ive had 1mm easy, that was dead, .05 should be ok But it's still gone soft, they can put hardened steel seats into the head if they get real bad and you don't want to replace, good luck with it and make sure the Coolant vent ball valve is clean and opening as it should!
D
D
- x 19
I like xud's .. you get a massive 10 meter thick repair gasket. Lose a fraction of compression and do a few more million miles
- x 1702
Fingers crossed all is going to be OK with the head John
- Sara Watson's Stalker
- x 4
- x 42
And its certainly not to anneal the honeycombe of alloy that is the K series head, trouble usually is the air bleed valve gets gummed, you loose compression into thewater jacket which air locks as the engine is usually higher than the rad, and its goodnight.
D
D
- x 19
well i am about to start with the rebuild..
going for a multi layer gasket but a bit nervous about it really.. engineer said its fine, even gasket instructions say the liner protrusion should be 0.00mm >
I have 0.04 - 0.05 as best as I can measure..
- x 1702
All the best John, I'm sure with your skill it'll be absolutely fine..
You've got t gorgeously clean
How? By hand or did you have assistance from a proper parts washer?
