Over active ABS sensor...the effect of "being on ice" when the light is out is caused by a Gap between sensor and ABS teeth being TOO BIG!!!
When the light is on, ABS is disabled, and so braking is as a car without ABS and all references to the Sensors and ABS teeth is completely ignored...
Have you had a front sensor fitted lately?? Or replaced the ABS ring on a CV joint?
Abs warning light
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Abs warning light
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Donor 2023
- My Cars: '00 Xantia 110 bhp Hdi SX Estate 65K "W"
'99 Xantia 110 bhp Hdi SX Estate 310K SORN "V"
'98 Xantia 1.9TD SX Estate 150K Sold "T" - x 47
Yes Paul, I just cleaned it today .. awaiting the arrival of a replacement.. Thanks for the info.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
Be sure the heat shield retaining part is not between the sensor and hub and between the bolt head and sensor..
the gap should be no bigger then well a wisker of a gap... virtually touching but not ifcthat makes sense..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
'13 3008 1.6 HDi GripControl - x 1002
Over active ABS also caused by a broken ring. If I were you Chris, I'd take the fuse out for the time being - being able to stop, albeit with the risk of a lock up, is better than not being able to stop...
- Donor 2023
Good idea Richard.. I'm pretty sure the ring isn't broken.. I had a good look at it this morning.. cleaning out some of the rusty spots on it just to make sure that wasn't the problem..
I'll give another go with the sensor bolt tomorrow and if that doesn't work .. out comes the fuse for a couple of days.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
On Gracie both rings were cracked and loose enough to cause the ABS an issue. However, when you looked at them it was not initially obvious that they had cracked, until I then touched them and found they could move.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Donor 2023
I've been hammering lightly the affected one, using a srewdriver to drive out the bits of rust between the castellations.. I'm sure it would have been obvious if the ring was broken.
Fuse removed predictable braking restored.
Kenny, how did you get on?
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Are you certain its a front ring? is it possibly a rear one causeing grief or have you had a lexia reading to see whats going on?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- KennyW
- My Cars: Current Citroen's
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Xantia 2.0 90hp estate
Xantia 1.9 TD estate - x 132
Chris,
After threatening the car with a lexia session and a drive through to RICHARDW , it showed an intermittent fault at driver's side front sensor.
The light has never reappeared and ever since.
This side I changed the CV joint and new ABS sensor cable.
So I have no idea what has happened, will check further when weather improves.
Kenny
Kenny
C5 x7 2.0 HDi 160 hp Estate exclusive, the newbie
C3 1.4 petrol (SWMBO)
Kenny, are you sure the new CV joint has the same outer diameter as the original ?
I believe there are a couple of different diameters for Xantias. Anything that causes the gap between the sensor and the teeth on the reluctor ring to be too great can cause the symptoms you're seeing because there is not enough signal output from the sensor at low road speeds when the gap is too large.
The gap should be enough to slide a piece of writing paper into and no more. As Paul mentioned already another possible cause of a larger than normal gap is getting the heat shield on the wrong side of the sensor flange.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Simon,
Yes it is the correct CV joint as it has been fitted for at least 9 or 10 months with no problems. I bought the wrong one at first which caused the light to be permenantly on.
Last night the light camne back on, I have a new ABS sensor which I'll fit today and see what happens. I think there maybe a small break in the wiring inside but it will be difficult to confirm.
I will report back after replacing same.
Otherwise, it might be the ring has broken but there is a 2 year warranty with the CV joint so hopefully no problems in replacing joint.I still have the receipt.
Kenny
Kenny
- KennyW
C5 x7 2010
SWMBO C3 2012
Previous Citroen's
Well, I had a better look today and firstly I've made a mistake. I replaced the nearside CV joint in the summer, the problems are on the offside. I've replaced the ABS sensor but I'll probably change this CV joint so that should cure the problem.
Kenny
Kenny
