AX keeps smoking white even when warm
Re: AX keeps smoking white even when warm
intake looks mad
99 silver 2.1td exclusive xantia
99 red 2.0 hdi exclusive xantia..
00 black 2.0 hdi exclusive xantia
99 blue 2.0 hdi exclusive xantia
06 silver 1.6 hdi vtr c5
57 blue C4 GP 1.6hdi exclusive
08 black C4 GP 2.0hdi vtr
Is it a petrol engine ?citronut wrote: do you mean bathroom sealant ???
If silicone based sealant has been used on the intake manifold and in enough quantity to produce smoke you can kiss the oxygen sensor good bye as it will be completely contaminated and probably non functional by now.
Oxygen sensors are sensitive to even small traces of silicone based substances used on intake manifolds, sump gaskets etc. I'd be checking the oxygen sensor still functions before the next MOT...
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
Remember all the problems several years ago with car breaking down? That was due to silicone on the petrol.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- jsp
- My Cars: AX 3x 10E 1.4 GTI 5drs 1.0i
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
1994 AX 1.4 5dr TGS GTI
1994 AX 1.0 3dr Escapade
1996 AX 1.1 3dr spot Burgundy
1996 AX 1.1 5dr Verte
2003 peugeot 206 xs leather with auto A/C - x 12
yes by previous owner.citronut wrote:so are you saying someone has installed a shower head or toilet cistern in the inlet manifoldjsp wrote:found bathroom kit between the intake manifold . so water is entering through the intake manifold. fingers crossed.citronut wrote:can you clarify what you are saying?????
no seriously joking aside
It just passed the mot without problem with loads of steam.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
yes....... what the **** and not around the coolant line but, around the fuel/air mix only.citronut wrote:so are you saying someone has installed a shower head or toilet cistern in the inlet manifoldjsp wrote:found bathroom kit between the intake manifold . so water is entering through the intake manifold. fingers crossed.citronut wrote:can you clarify what you are saying?????
My Citroens update:
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Got it sorted now. Running fine.
My Citroens update:
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1206
What was it?
Burning bathroom sealant by the sound of it!
Simon
1978 CX 2400
1978 CX 2400
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Bathroom sealant let loose coolant can enter the intake manifold hence the smoke. Got some black liquid gasket redo the whole gasket and smoke free now.
My Citroens update:
How does a leaking air inlet manifold gasket let coolant into the intake ?? What does "loose coolant" mean ?
I would have thought unless you have a bad external leak in the cooling system that is leaking coolant all over the exterior of the engine, or a blown head gasket it wouldnt be possible for coolant to reach the inlet in any quantity...
A leaking intake manifold gasket should only cause a vacuum leak that makes the engine run lean. Doesn't make sense to me.
Simon
1978 CX 2400
1978 CX 2400
I've dealt with engines in the past where the inlet manifold has coolant running through it and the inlet manifold gasket has provided a "seal" for the waterways in and out of the head. Saab 900 16v Turbo for one. I was not aware of this until we fitted the wrong inlet manifold gasket after an engine replacement and got a shower on startup, therefore I could see how it would be possible.
It looks like there's a carb base heater arrangement on that manifold in the pic with similar outlets at the head end of the manifold. If there wasn't a good seal I could see how water could get sucked into the cylinders.
Simon if you look at the manifold to head surface there are to ports below the intake ports, these will have coolant running through them
Regards, malcolm.
That's exactly what I meant Thanks Malcolmcitronut wrote:Simon if you look at the manifold to head surface there are to ports below the intake ports, these will have coolant running through them
- jsp
CX 2x GTI turbo
ID 19 1960
Now:
1960 ID 19
1984 CX GTI Turbo 1
1987 CX GTI Turbo 2
1987 AX 10E Pino
Citroen makes weird coolant lines through the intake manifold.Mandrake wrote:How does a leaking air inlet manifold gasket let coolant into the intake ?? What does "loose coolant" mean ?
My Citroens update:
Ah, so is that a carburettor model ? It's so long since I've seen a carburettor engine I'd forgotten that the intake manifolds are sometimes heated. (With exhaust gas on my old GS though, I haven't owned one with coolant heating of the manifold)
It just goes to prove my comment earlier though that you can't rely on checking for a drop in fluid levels when looking for the source of what was being burnt - you specifically said no coolant was being lost in your first post. (as well as no brake fluid or oil) Clearly some was being burnt but not enough to cause a visible drop in the level.
Glad its sorted!
Glad its sorted!
Simon
1978 CX 2400
1978 CX 2400
