You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
c5 x7 2009 rear light, plug burning out??
Re: c5 x7 2009 rear light, plug burning out??
- My Cars: Renault 14...now skyward
Renault 19.. skyward also..
'03 Xsara 1.8 Picasso in silver met his maker
'06 Desire, again in silver also gonn to metal heaven
if I am stuck behind a persistent brake pedal pusher, I position my car so that I can see his mirrors,I turn on my headlights till he releases the pedal, and so on.
btw way why DO people insist on using indicators in a dedicated turn lane, like out of supermarket car parks, and never bother to use indicators on roundabouts????
- Locked user account
- My Cars: A used Citroen
- x 27
I guess the break thing is somewhat cultural ... ... on our roads, it's a minority that doesn't break on the traffic light, so I guess you'd burn out your headlights over here ... ... I do understand the reasoning, and can agree on it that the driver behind is bothered by the more intensive red glow, but honestly, what bothers me more on the roads are drivers who don't want to switch from high to dipped beam in the middle of the night while driving towards you ...
i was always taught at a stop junction or red trafic lights you are meant ( in a manual at least ) to take it out of gear and have the hand brake on,
this is what always constituted as a stop,
as modern car brake lights are so so much brighter these days, it is not comfortable sitting behind a car at lights with there brake lights burning into your eye ball,
Regards, malcolm.
not if the idle speed is set correctlyXantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Regards, malcolm.
- My Cars: Now:
C5 X7 HDi 240 Exclusive Tourer
ZOE 22kwh Intense
Before:
C4 1,6 Coupe Automatic
C5 X7 HDi136 Exclusive Sedan A
Xantia HDi110 Berline
Xantia 1,8SX Berline - x 28
So you mean I should put gear on N and activate electric handbrake always at traffic lights?!!northern_mike wrote:You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Btw, If I remember correctly, that doesn´t help, because the handbrake activates brakelights too.
- My Cars: Now:
ZOE 22kwh Intense
Before:
I don´t understand what you mean? My idle speed is set correctly (how can it not be on these modern HDi-engines?).citronut wrote:not if the idle speed is set correctlyXantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
And I thought that it´s normal for a car with automatic transmission to move forward when on D and no brakes on?
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1290
- Contact:
Yes, If it does not hold the car it is not working correctlyXantippa wrote:So you mean I should put gear on N and activate electric handbrake always at traffic lights?!!northern_mike wrote:You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Btw, If I remember correctly, that doesn´t help, because the handbrake activates brake lights too.
Yes, you take a geared car out so why not an Automatic ?, it is basic road manners to the driver behind you. Why would you wish or not care about causing them discomfort and reduce their night vision ?
and
mine does not
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3007
When I was learning to drive my instructor taught me to use the handbrake and put the car in neutral if I felt that I was going to be stopped for more than 5 seconds. That was mainly for good manners (not dazzling the drivers behind), as well as making the car more secure (if I were hit up the back it is likely my foot would slip off the brake pedal).
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Stickyfinger
AX, little Daffodil
- Contact:
or smash your ankle joint when they impactHell Razor5543 wrote:(if I were hit up the back it is likely my foot would slip off the brake pedal).
thereStickyfinger wrote: or smash
that would stop them holding there lazer brake light on in front of youStickyfinger wrote: ankle joint
Regards, malcolm.
- My Cars: Now:
ZOE 22kwh Intense
Before:
Well, If you knew how much it does cost to replace hand brake cables on C5 X7 with electric hand brake, you wouldn´t use it too much.
- My Cars: C4 Picasso 1.6 Blue Hdi 120 Manual Excl+ 2016
C3 1.2 Puretech 110 Auto Flair 2017 - x 99
It is possible to have that combination without sitting at traffic lights with your foot on the brake.rear lights, indicator, rear fogs all on at once it won't cope and ..
In some places we have hills, fog and junctions that you need to slow down for
Richard_C
Current: , C4 Picasso 120 BlueHdi, C3 1.2 Auto
Past Citroens: Dyane (x2), 2CV, Visa, BX (x2), Xantia, Xsara Picasso, C3 (x2) C5 X7 Tourer, Synergie 1.9TD, C1
Others: Hillman Hunter, Cortina Mk 1, Maxi, VW Type 2, Granada, SAAB 900, SAAB 9-5, R5 Gordini
- Stickyfinger
AX, little Daffodil
- Contact:
and if appropriate, your lights should be used, I do not think anybody thinks otherwise.Richard_C wrote:It is possible to have that combination without sitting at traffic lights with your foot on the brake.rear lights, indicator, rear fogs all on at once it won't cope and ..
As for cables, Lube e'm and Use e.m or Loose e'm.
- My Cars: CITROËN C5 (X7 ) 2.0 HDI 140ps
Hello
I have the same problem with my c5 x7 2.0hdi 140ps 2010 model. The left rear led indicator stops working every week. When i stop the car after 1 hour works fine. Checked With my lexia and found errors like front right indicator problem,rear left indicator problem..etc for all indicator...
The connectors are all ok and no melting points.
I will attempt to make a by pass ground to the rear left light and i will let you know if the problem is still here.
Thanks for the technical ideas....
Keep the good job.
George
Keep the good job.
George
