Hell Razor5543 wrote:Make sure, if you do decide to buy a Lexia, that it has a higher version of DiagBox than 5.29. The Chinese clones have had some of their firmware blacklisted, and can only work with versions up to 5.29.
You must also make sure that the O/S of the computer you are going to use is 32bit, or can have a decent 32bit Virtual Machine with clean access to the USB systems. This is because Lexia is a very old piece of software, and cannot function in a 64bit environment.
Diagbox is a smart piece of software, and will, when the need arises, call up the Lexia or Planet Peugeot software.
And what is PP2000 used for ?
Does this seem appropriate?
http://www.custojusto.pt/lisboa/pecas-c ... ox-3764906" onclick="window.open(this.href);return false;
