Car won't start!
Re: Car won't start!
Sorry for dragging this out fellas but after checking again (late last night when the road was quiet) it seems the lift pump is priming! Do I go for the camshaft/ crankshaft sensors as Hamster posted ( where are they??)!
- darbuck
- Donor 2023
- My Cars: 2008 Citroen C5 X7 Tourer VTR+ (138 BHP)
2007 Nissan Primera P12 1.6 T-Spec (110BHP)
2003 Citroen C5 Estate level 2 (110 BHP) 2.0 HDI
2001 Nissan Maxima QX 2.0 V6 - x 143
If its the same hdi unit as the c5 the cam sensor is at the rear centre of the upper timing belt cover
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
I think from memory the crankshaft sensor is in the 10 o'clock position when you look straight at the crankshaft pulley.
Bear in mind that you will only be able to check the connectors are plugged in or not. You will need to use a lexia to determine if they are working. It will give you an error code to tell you.
Where are you based? There might be a member with a lexia who would be willing to help out.
Rob
Rob
15 C4 1.6 eHDI 115 Exclusive - better half's
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Cheers Rob
Will check the connectors soon as. Live in Ayrshire m8.
just been out to check and can't see any connectors around the cam belt area Rob?? Excuse the ignorance here but is there a way to check whether fuel is getting to the rail so that I can eliminate the pump question? as the lift pump seem to me like it's energising when the key is turned to the second position.
'13 3008 1.6 HDi GripControl - x 1003
Whereabouts in Ayrshire? Mandrake, DHallworth and I are not a million miles away. I'd offer, but flat out up to Christmas so can't come out to it - if it was mobile I could plug it in at mine
- My Cars: Citroens since 1990, BX Diesel, GTI, TZD with 1.9 TD running extra boost before it was fashionable!, ZX Volcane TD, S2 Xantia break 1.9TD, Xantia HDI 110, currently zipping about in a C2 Diesel. C2 died from the dreaded worm, C3 Picasso HDI Exclusive, the adventure continues.
- x 31
The pump/sender units seem to look the same whether theres a pump in there or not, I took a couple out in the breakers and the non pump jobs appear to have a place for the pump, though comparing the electrical connectors might give a clue, I used a hammer and screwdriver to tap the locking ring around and it undid easily. I think HDI 110 motors with bosch injection have them. so plenty of potential donors out there.
