c5 sat navigation screen
This unit is the RT4 and RT5 system and is made by Magneti Marelli
Main differences between RT4 & RT5 - RT5 has Bluetooth Hands Free, faster Navigation calculation and on C4 & C4 Picasso only, USB ports and a High-Res screen.
Moderator: GiveMeABreak
scottspark
My Cars:
Re: c5 sat navigation screen
Post by scottspark »
Took it out and stripped it, looking attitude everything looks ok to me and put back in but just the same. It looks like a new screen I need. Do you no where to get these from as I don't fancy paying dealer prices. I've searched through eBay but there is done for my car.
Thanks again
vborovic
Locked user account
My Cars: A used Citroen
x 27
Post by vborovic »
The used screens are hard to find, because not that many are being sold, and the latest C5s aren't in scrapyards yet ... I gave it a quick search, here's one find: http://www.ebay.de/itm/Display-Bildschi ... 56600b6fff" onclick="window.open(this.href);return false; ... as you haven't told us what navigation you have, I'm guessing you have the smaller screen (there are 2 versions actually), the RT4 & RNEG have a slightly smaller one, while the RT6 and 3d Navidrive have a larger one (known as DG4 screen) ... difference is under 3 mm ...
My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally
x 1280
Contact:
Post by Stickyfinger »
Hio, not much to add but as a rule of thumb, I NEVER trust that cables are OK, I mess with computers a lot and it is not uncommon for the cables to be faulty....it may be worth checking them by putting a few volts thru each wire and check for high resistance or failure.
This last came to prove itself when chasing a AirBag fault, a chaffed wire further up the seat/airbag loom making an earth.....if you have it at hand check it before it goes back on....
Activa, the Moose Rider
3x C5x7 Steering racks and counting
AX, little Daffodil
x 1280
Contact:
is this one ?
http://www.ebay.de/itm/like/23136629680 ... rid=229487
They seem VERY rare.....even if you snapped one up and did not need it you will be able to re-sell it easy so should not loose out
scottspark
My Cars:
i believe its the rt4 with the hdd they screens are different to the one thats in mine. see pic its a different code and different back
My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl
x 983
Post by RichardW »
There appear to be quite a few different part nos, no idea what the real differences are!
6593 71
RP 6593 Q4 DISPLAY
- DISPLAY (NAVIGATION+VIDEO+RADIO+CLOCK, TEMP, CD) SINCE DATE 20070924 UNTIL DATE 20100111
6593 Q4
- DISPLAY (NAVIGATION+VIDEO+RADIO+CLOCK, TEMP, CD) SINCE DATE 20100112
6593 71
RP 6593 Q4
- DEV DISPLAY UNTIL DATE 20100111
6593 Q4
- DEV DISPLAY SINCE DATE 20100112
6593 F6
- DISPLAY DG4 SINCE RPO 11690 UNTIL RPO 12111 EXCEPT 1ST WINDOW 2010 / BEFORE 1ST WINDOW 2012
6593 Q5
- DISPLAY DG4 AND 1ST WINDOW 2008 / BEFORE 1ST WINDOW 2010 UNTIL RPO 12165
6593 R9
- DISPLAY DG4 AND 1ST WINDOW 2010 / BEFORE 1ST WINDOW 2012 SINCE RPO 12166 UNTIL RPO 12209
- DISPLAY DG4 SINCE RPO 12210 UNTIL RPO 12551
6593 Q5
- DISPLAY DG4 SINCE RPO 12552 UNTIL RPO 12803
6593 R9
- DISPLAY DG4 SINCE RPO 12804 UNTIL RPO 12848
98 008 360 80
- DISPLAY DG4 SINCE RPO 12849 UNTIL RPO 13019
98 010 200 80
- DEV HR DISPLAY SINCE RPO 13020
Citroen prices are 'interesting' :twisted: [-X
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00006593F6 DISPLAY 713.60 GBP 856.32 GBP 856.32 GBP
00006593Q4 DISPLAY 670.93 GBP 805.12 GBP 805.12 GBP
00006593Q5 DISPLAY 520.75 GBP 624.90 GBP 624.90 GBP
00006593R9 DISPLAY 643.51 GBP 772.21 GBP 772.21 GBP
9800836080 DISPLAY 643.51 GBP 772.21 GBP 772.21 GBP
9801020080 DISPLAY 981.98 GBP 1,178.38 GBP 1,178.38 GBP
If you post up the last 8 digits of the VIN I can confirm the exact part number - I suspect it is used in other cars as well, so should be able to provide a list that may help with finding a breaker.
scottspark
My Cars:
The last 8 of vin 54042557
Thank you
x 983
Post by RichardW »
Yours is:
02
6593 71
RP 6593 Q4
01
01
DISPLAY
So originally 659371, now replaced by 6593Q4.
659371 also used in some C4s;
6593Q4 also used in:
1 document(s) found for C4
1 document(s) found for DS3
1 document(s) found for C5 (X7)
1 document(s) found for C3 (A51)
Mandrake
My Cars:
x 664
Post by Mandrake »
I think it's about time Citroen paid you for being their parts look up man Richard! :rofl2:
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
Post Reply
