It’s often sticky brushes and the guilty party can sometimes be persuaded to run by giving it a spin with a stick...
Xantia fans can be very frustrating
It always happens... The set I got yesterday to rebuild Gabriel's fans are immaculate except one relay that's just beginning to show signs of corrosion on the lowermost pin....white exec wrote:corroded blade contacts the most common problem
And why relay bases are so easily cooked when there's a bit of corrosion present Chris! Xantia fans motors are supplied by their own individual 40A Maxi Fuse...white exec wrote: That latter (for V6 and 2.5 on the XM) involves some serious running current at 12v-14v!
Grille off, fan blade assemblies off noting that unless clipped (rare on the high-wattage ones) the fan blade assembly centre fixing screw has an LHD thread...elma wrote:So how do the fans come out of a V6?
Yes, but you recalled it and took the trouble so you are entitled to thanks too Steve!myglaren wrote:^ Swiped from Simon's blog so it is he who deserves the thanks- I remember vividly his trials and tribulations with it.
