C5 Nightmare
Re: C5 Nightmare
Battery changed, no luck
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1280
- Contact:
Re: C5 Nightmare
Does not matter, can be damaged easy. Have you looked at the internals ?? (Do not stick your finger in there, just look !)dubburke wrote:The engine does seem to rev better when the MAF is disconnected, but it was only replaced apparently last November by Citroen.
Still, you need a Lexia session mate.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Re: C5 Nightmare
Will take a look stickyfinger
Re: C5 Nightmare
Anyone close to me in N.Ireland? on the North coast, need this car sorted, as i cannot afford another one.
Sorted the "suspension faulty" message, by just removing the cap to the hydraulic resevoir, there was a hiss, i put the cap back on, and it now works!!
Forgot to say, the battery keeps going flat, even though it has been swapped for a good one.
Re: C5 Nightmare
Not sure if it would sort any of the problems you're experiencing, but to my mind, I'd first be looking at sorting out why the battery's going flat. If not battery, is alternator 100%? Maybe a low level permanent drain such as the boot lamp not switching off, or a faulty radio/intruder alarm?dubburke wrote:the battery keeps going flat
Martin
1995 Xantia TDLX (deceased )
Re: C5 Nightmare
Thanks, Vehicle is not being used, so it must be a drain, will take out bulbs in the boot and see if it still goes flat!
- My Cars: Renault 14...now skyward
Renault 19.. skyward also..
'03 Xsara 1.8 Picasso in silver met his maker
'06 Desire, again in silver also gonn to metal heaven
Re: C5 Nightmare
I have a '03 Xsara Picasso. and as a drain on the system has come up..in the previous post,
just how much is still "alive / awake" after its been central locked, I wonder.....
- Zelandeth
- My Cars: 2006 Peugeot Partner Escapade 1.6HDi.
1988 Renault 25 Monaco 2.0i.
1985 Sinclair C5.
1984 Trabant 601S.
1975 Rover 3500.
1973 AC Model-70. - x 1403
- Contact:
Re: C5 Nightmare
First thing I would suggest is pull each fuse with the vehicle locked (just with the key, not remote) and connect an ammeter across the terminals. Anything that's higher than 100mA is subject to suspicion.
Current fleet:
06 Peugeot Partner Escapade 1.6HDi, 88 Renault 25 Monaco, 85 Sinclair C5, 84 Trabant 601S, 75 Rover 3500, 73 AC Model 70.
