Hello Everyone
- myglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4917
Re: Hello Everyone
You have removed or turned out of the way the 'hockey stick' bolts?
- My Cars: 2008 Laguna 1.5 DCi
- x 235
Re: Hello Everyone
Hi Mate,myglaren wrote:You have removed or turned out of the way the 'hockey stick' bolts?
I did remove the 2 hockey stick bolts yesterday The bearing just wont move, I have the shaft pulled towards the drivers side now and the gearbox is back in. Only 74 k on the car but it seems to have been neglected.
Oh buggle
- CitroJim
- x 6182
- Contact:
Re: Hello Everyone
They can be utter ***** to move.
I've resorted to a specially ground cold chisel to act as a punch and walloped the bearing with a 4 lb club hammer before now and on one occasion actually shattered the bearing in the housing...
Generally though if you attack them with a cold chisel (ground so as to fit snugly against the drive shaft lip) rotate the shaft as you land blows they do normally give up gracefully.
- x 235
Re: Hello Everyone
I'm doing it on the ground so space is limited. Any way of removing it that doesn't involve a grinder?
Oh buggle
- x 235
Re: Hello Everyone
Thanks mate I'll give it another go after church tomorrow if I wreck the bearing is it new shaft time? There's more skin on a rice pudding than on my hands since Friday I still have the belt to doCitroJim wrote:They can be utter ***** to move.
Oh buggle
- CitroJim
- x 6182
- Contact:
Re: Thanks guys
Great newsdoctle wrote:Car is back together thanks everyone for the help advice and info
How did the driveshaft centre bearing go in the end?
- x 235
Re: Thanks guys
Hi, It wouldn't move. I unbolted the carrier from the engine and aligned it when fitting the gearbox. took a while but it's back driving. There was plenty of wear left on the clutch but the pressure plate was very rusted and the release bearing was in shreds.CitroJim wrote:Great newsdoctle wrote:Car is back together thanks everyone for the help advice and info
Oh buggle
- CitroJim
- x 6182
- Contact:
Re: Thanks guys
Great stuff.. At least the job is all nicely done now. I trust you replaced the complete clutch and not only the release bearing....doctle wrote:Hi, It wouldn't move. I unbolted the carrier from the engine and aligned it when fitting the gearbox. took a while but it's back driving. There was plenty of wear left on the clutch but the pressure plate was very rusted and the release bearing was in shreds.CitroJim wrote:Great newsdoctle wrote:Car is back together thanks everyone for the help advice and info
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
Re: Hello Everyone
good stuff Doctle
I had a V6 406 coupe with a stuck intermediate bearing, very frustrating.. in the end I took the whole auto box and what was left of driveshaft to an autobox specialist..
He put all of it on an old oil barrel, and hit with a serious lump hammer.. many times,,
it came apart then
John
it came apart then
John
- x 235
Re: Thanks guys
Hi Jim,
Yes all replaced it's too much work to split it again in a year.
Thanks again you guys are all very helpful
I'll be back with more questions soon
Paul
Paul
Oh buggle
- CitroJim
- x 6182
- Contact:
Re: Hello Everyone
I remember that well John and in fact I have a spare 4HP20 here with exactly the same problem. It has the stub of a drive shaft stuck in it. A stub because most of the drive shaft got cut off after many attempts to remove it failed!!!jgra1 wrote: I had a V6 406 coupe with a stuck intermediate bearing, very frustrating.. in the end I took the whole auto box and what was left of driveshaft to an autobox specialist..
I'll most likely deal with it when I strip the 'box to overhaul it...
Paul, excellent Keep the questions coming
