Filler Cap Button
momag46
My Cars: 1999 Xantia V6
x 53
Re: Filler Cap Button
Post by momag46 »
wheeler wrote:Just noticed this thread, xsaras also have this 'button'. They have no electrical connections whatsoever, purley mechanical.
From what I understand when the cap is removed it shuts off a chamber somewhere in the filler neck so that the tank cant be truly filled to 'the brim', when the cap is put back on the chamber is opened again leaving space for expansion of the fuel. if you have ever had a plastic jerry can of petrol on a hot day you will see the pressure that builds up in them. Not sure if its on diesel models aswell but my petrol Xsara has it.
Thanks for that - this seems like the probable answer.
I spoke to Barry today and he thought it was to allow fumes to be released BUT the above looks more likely.
When I originally asked the question I expected an instant answer but I was wrong.
Just when you think 'everything you want to know about Citroens is on this site' you're let down :twisted:
Maurice
1999 V6 Xantia
Donor 2023
My Cars: C5 Mk2 VTX+ estate.
x 3008
Post by Hell Razor5543 »
momag46 wrote:When I originally asked the question I expected an instant answer but I was wrong.
Just when you think 'everything you want to know about Citroëns is on this site' you're let down :twisted:
Maurice
That's not fair! :-D Every question has to have a first time of asking, and then everybody goes off to find the answer. At least you got several to choose from. :lol:
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Mandrake
My Cars:
x 666
Post by Mandrake »
I agree wheelers explanation seems most plausible, but I think it's by no means certain. If so why do some Xantia's not have this button ?
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
Donor 2023
x 3008
If the difference is between diesel and petrol tanks, then probably because petrol is more volatile, and so has a faster evaporation rate than diesel, so needs a bigger vent than a diesel tank.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
My Cars:
x 733
Post by wheeler »
On modern petrol cars fuel vapour is 'vented' into a charcoal cannister, the ecu can then recylce it back into the engine when it sees fit via a small electrovalve.
Mandrake
My Cars:
x 666
Post by Mandrake »
wheeler wrote:On modern petrol cars fuel vapour is 'vented' into a charcoal cannister, the ecu can then recylce it back into the engine when it sees fit via a small electrovalve.
Yep, and a Xantia is modern enough to have this.
The canister and electrovalve is under the left hand front wing right up near the top, at least on the V6, but I suspect its in the same place on all petrol Xantia's as there isn't really anywhere else to fit it as the canister is quite large!
A pipe comes through a hole in the wing past the battery to connect it to the inlet manifold at the throttle plate. Occasionally at idle you'll hear a "click click click click" coming from the front left wing - that's the electrovalve at work releasing stored vapours to be burnt.
Simon
1978 CX 2400
Donor 2023
x 3008
I wonder. Is it possible that the green button locks the flap in the closed position, thereby sealing the tank and preventing fumes getting out through the filler point, and limiting petrol escaping in the event of an accident?
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
momag46
x 53
Post by momag46 »
Hell Razor5543 wrote:I wonder. Is it possible that the green button locks the flap in the closed position, thereby sealing the tank and preventing fumes getting out through the filler point, and limiting petrol escaping in the event of an accident?
No - with the button pushed in or left out and the car locked, the flap is free to open.
Everything above adds up to a load of sense. The bit about heat and expansion also makes sense, the plastic pan I use for the lawnmower comes up like a balloon - now I use super unleaded in the mower, as in the Xantia, it goes like crazy. I get the lawn cut in half the time but leave skid marks where it's dragged me along :lol: :lol: :lol: :rofl2:
Maurice
1999 V6 Xantia
Post Reply
